Air conditioners? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air conditioners? (/showthread.php?tid=9401) |
Air conditioners? - rlrueter - 06-06-2011 03:20 Hi I got an 82 fc35 last fall. It will be in the high 80s and 90s today and tomorrow. Just tried to turn on the Air Conditioners. All three do nothing. I followed the general operation section in the manual. All three breakers are on. Is there a trick or a hidden switch or something. Air conditioners? - Ralph - 06-06-2011 05:59 Go to the drivers seat. There should be 3 switches to the left of the drivers seat or on the over head. Those switches control the ac's or heaters depending on which way the summer\winter switch. Winter is heat. Summer is ac's Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "rlrueter" Sender: WanderlodgeForum@yahoogroups.com Date: Mon, 06 Jun 2011 15:20:14 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Air conditioners? Hi I got an 82 fc35 last fall. It will be in the high 80s and 90s today and tomorrow. Just tried to turn on the Air Conditioners. All three do nothing. I followed the general operation section in the manual. All three breakers are on. Is there a trick or a hidden switch or something. ------------------------------------ Yahoo! Groups Links Air conditioners? - rlrueter - 06-06-2011 12:38 Well I found the Summer/Winter switch and corrected that but still nothing...humm, dang its hot out today! Any further ideas? --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > Go to the drivers seat. There should be 3 switches to the left of the drivers seat or on the over head. Those switches control the ac's or heaters depending on which way the summer\winter switch. Winter is heat. Summer is ac's > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "rlrueter" > Sender: WanderlodgeForum@yahoogroups.com > Date: Mon, 06 Jun 2011 15:20:14 > To: > Reply-To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Air conditioners? > > Hi > I got an 82 fc35 last fall. > It will be in the high 80s and 90s today and tomorrow. > Just tried to turn on the Air Conditioners. > All three do nothing. > I followed the general operation section in the manual. All three breakers are on. > Is there a trick or a hidden switch or something. > > > > ------------------------------------ > > Yahoo! Groups Links > Air conditioners? - Curt Sprenger - 06-06-2011 12:56 Post your phone # and I'll bet someone with your year/model will call you. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" On Mon, Jun 6, 2011 at 5:38 PM, rlrueter <"rlrueter@mac.com"> wrote:
Air conditioners? - rlrueter - 06-06-2011 13:08 Thanks..... 320-292-0146 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Post your phone # and I'll bet someone with your year/model will call you. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > curtsprenger@... > > > > On Mon, Jun 6, 2011 at 5:38 PM, rlrueter > > > > > > > > > Well I found the Summer/Winter switch and corrected that but still > > nothing...humm, dang its hot out today! Any further ideas? > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > > > Go to the drivers seat. There should be 3 switches to the left of the > > drivers seat or on the over head. Those switches control the ac's or heaters > > depending on which way the summer\winter switch. Winter is heat. Summer is > > ac's > > > Safe travels, Ralph & Charolette Fullenwider > > > '84 FC35 "Ruff Diamond" > > > Duncan, Oklahoma > > > Sent via BlackBerry by AT&T > > > > > > -----Original Message----- > > > From: "rlrueter" > > > Sender: WanderlodgeForum@yahoogroups.com > > > Date: Mon, 06 Jun 2011 15:20:14 > > > To: > > > Reply-To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Air conditioners? > > > > > > Hi > > > I got an 82 fc35 last fall. > > > It will be in the high 80s and 90s today and tomorrow. > > > Just tried to turn on the Air Conditioners. > > > All three do nothing. > > > I followed the general operation section in the manual. All three > > breakers are on. > > > Is there a trick or a hidden switch or something. > > > > > > > > > > > > ------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > > > > > Air conditioners? - George Burke - 06-06-2011 19:24 This may be a dumb question on my part, as I only have read the last couple of your posts, but do you have the thermostats set at a low setting, or does that matter on your model? Â George Burke 1977 FC31 Charlotte On Mon, Jun 6, 2011 at 8:38 PM, rlrueter <"rlrueter@mac.com"> wrote:
Air conditioners? - g_man1146 - 06-07-2011 02:31 Did you turn on the threed switches that Ralph mentioned? Rich D. '06 M450 LXi CT --- In WanderlodgeForum@yahoogroups.com, "rlrueter" > > > Well I found the Summer/Winter switch and corrected that but still nothing...humm, dang its hot out today! Any further ideas? > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > Go to the drivers seat. There should be 3 switches to the left of the drivers seat or on the over head. Those switches control the ac's or heaters depending on which way the summer\winter switch. Winter is heat. Summer is ac's > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "rlrueter" > > Sender: WanderlodgeForum@yahoogroups.com > > Date: Mon, 06 Jun 2011 15:20:14 > > To: > > Reply-To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Air conditioners? > > > > Hi > > I got an 82 fc35 last fall. > > It will be in the high 80s and 90s today and tomorrow. > > Just tried to turn on the Air Conditioners. > > All three do nothing. > > I followed the general operation section in the manual. All three breakers are on. > > Is there a trick or a hidden switch or something. > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > Air conditioners? - Dick - 06-07-2011 03:32 Check the circuit breakers in the 120 volt house current box...CBs should be labeled for AC/Heat. If breakers have tripped, cycle completely off and then back on. Be sure to have electric toe kick heaters turned OFF or you may be running heat and AC at the same time. --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > Did you turn on the threed switches that Ralph mentioned? > > Rich D. > '06 M450 LXi CT > > --- In WanderlodgeForum@yahoogroups.com, "rlrueter" > > > > > > Well I found the Summer/Winter switch and corrected that but still nothing...humm, dang its hot out today! Any further ideas? > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > > > Go to the drivers seat. There should be 3 switches to the left of the drivers seat or on the over head. Those switches control the ac's or heaters depending on which way the summer\winter switch. Winter is heat. Summer is ac's > > > Safe travels, Ralph & Charolette Fullenwider > > > '84 FC35 "Ruff Diamond" > > > Duncan, Oklahoma > > > Sent via BlackBerry by AT&T > > > > > > -----Original Message----- > > > From: "rlrueter" > > > Sender: WanderlodgeForum@yahoogroups.com > > > Date: Mon, 06 Jun 2011 15:20:14 > > > To: > > > Reply-To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Air conditioners? > > > > > > Hi > > > I got an 82 fc35 last fall. > > > It will be in the high 80s and 90s today and tomorrow. > > > Just tried to turn on the Air Conditioners. > > > All three do nothing. > > > I followed the general operation section in the manual. All three breakers are on. > > > Is there a trick or a hidden switch or something. > > > > > > > > > > > > ------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > Air conditioners? - James Q Riordan Jr - 06-07-2011 09:55 Shore power or generator? Thanks Jim Riordan
On Jun 6, 2011, at 11:20, "rlrueter" <"rlrueter@mac.com"> wrote:
Air conditioners? - wbostow - 06-08-2011 15:01 If the thermostats are replacements, they may have dead batteries. The thermostats will operate the ac via relay switches. You can purchase a voltmeter these days at a dollar store. Check both the low voltage and, if you feel knowledgeable enough, the main power at the relays. If you have a doorbell, it probably works on the same voltage as the thermostats. Does it work? Check for green crud around ground wires (usually green or black). Low voltage systems will be small wires, no larger than lamp cord. Thick wires, like on a household toaster or thicker, will be full voltage. Make sure power is OFF before doing anything other than testing. Tester rules: clip one side to ground, hold probe with one hand, keep other hand behind your back, wear rubber-soled shoes. I once had my household ac not come on. Turned out ants had nested in the relay switch. I cleaned and dusted, lubricated, and was back in business, saving what others may have paid about 5 grand. There are sharks out there! Somewhere, somehow, this has to be simple. (Three compressors didn't burn up at the same time.) Look for the unexpected, corrosion, bugs, mud, broken wires, dead A cells, series wiring with one broken link. If you have a decent parts place nearby, try to get the guy to show you replacement items (relay switches, etc.) Photograph them on your digital camera. Find and compare with what's on your bus. Be safe, keep trying, and keep us posted. --- In WanderlodgeForum@yahoogroups.com, "rlrueter" > > > Well I found the Summer/Winter switch and corrected that but still nothing...humm, dang its hot out today! Any further ideas? > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > Go to the drivers seat. There should be 3 switches to the left of the drivers seat or on the over head. Those switches control the ac's or heaters depending on which way the summer\winter switch. Winter is heat. Summer is ac's > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "rlrueter" > > Sender: WanderlodgeForum@yahoogroups.com > > Date: Mon, 06 Jun 2011 15:20:14 > > To: > > Reply-To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Air conditioners? > > > > Hi > > I got an 82 fc35 last fall. > > It will be in the high 80s and 90s today and tomorrow. > > Just tried to turn on the Air Conditioners. > > All three do nothing. > > I followed the general operation section in the manual. All three breakers are on. > > Is there a trick or a hidden switch or something. > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > |
