1995 WLWB 42' Water Plumbing. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1995 WLWB 42' Water Plumbing. (/showthread.php?tid=9409) |
1995 WLWB 42' Water Plumbing. - Ron Thompson - 06-11-2011 09:39 To anyone. I am going to convert my dual pump system to a single Shurflo Smart Sensor 5.7 gallon per minute pump. My question is, has anyone identified all the pipes that are coming into the area where all the old pump connections are with the dual pump system? I am removing the water storage cannister also. I know that Pete Masterson converted his system and he had the same coach that I have. I don't know if Pete did the work himself or had it done by a shop. I have about three photo's of his conversion including the old setup and the finished conversion. However I can't tell anything about the pipes bringing the water in or the pipes taking it out to the other areas of the coach. I could just put water in the fresh water tank and see what pipes it comes out of but that is just a bit messy. I might have to resort to that though. If you have done this conversion and you have a coach that would have the same piping as mine I could sure use some advice. Thanks for any help. Ron Thompson 1995 WLWB 42' |
