Air Compressor Coolant Hoses - Ernie E - 06-13-2011 23:30
If yours has never been replaced, those two hoses can break. The fittings most
likely can be reused. The hoses are not that expensive. A burnt up engine will
cost up to 20 grand. The hoses on my 8v fell apart in our hands. Was lucky to
arrive back home after maiden trip from Georgia. 6v92s have them too.
Ernie- 88PT40- in Texas- new hoses= peace of mind
Air Compressor Coolant Hoses - Rick Gunther - 06-17-2011 02:40
Ernie, That used to be a problem on 6v92 in fire apparatus. If you are interested, email me at "racerracer@buckeye-express.com" and I will find the hose we used. Fire pumpers sit and pump for days sometimes and the hoses would break off due to heat exposure in a very confined mid engine doghouse. The hoses we used solved that issue and would last for years of abuse.
Rick in Ohio
--- On Tue, 6/14/11, Ernie E wrote:
Subject: [WanderlodgeForum] Air Compressor Coolant Hoses
Date: Tuesday, June 14, 2011, 7:30 AM
If yours has never been replaced, those two hoses can break. The fittings most likely can be reused. The hoses are not that expensive. A burnt up engine will cost up to 20 grand. The hoses on my 8v fell apart in our hands. Was lucky to arrive back home after maiden trip from Georgia. 6v92s have them too.
Air Compressor Coolant Hoses - Ernie Ekberg - 06-17-2011 02:47
Hi Rick, can you upload that info in the database? That would be helpful for all of us. Thanks, Ernie- currently in dried out Lubbock, Tx
88 PT40
817-475-3991
--- On Fri, 6/17/11, Rick Gunther wrote:
Subject: Re: [WanderlodgeForum] Air Compressor Coolant Hoses
Date: Friday, June 17, 2011, 9:40 AM
Ernie, That used to be a problem on 6v92 in fire apparatus. If you are interested, email me at racerracer@... and I will find the hose we used. Fire pumpers sit and pump for days sometimes and the hoses would break off due to heat exposure in a very confined mid engine doghouse. The hoses we used solved that issue and would last for years of abuse.
Rick in Ohio
Air Compressor Coolant Hoses - Rick Gunther - 06-17-2011 09:01
Not sure what you mean by upload into the database. I would have to wait for my 9 year old nephew to come over! LOL! Here is the info off a piece of the hose I use in my solvent tank:
DAYCO 7212 Jiffy Hose Push On 300 psi max WP MSHA 1C-12345 CFI 2093
this is for 1/2" ID. It is grey in color. Hope this helps.
-Rick in Ohio
Date: Friday, June 17, 2011, 10:47 AM
88 PT40
817-475-3991
Rick in Ohio
Air Compressor Coolant Hoses - Ernie Ekberg - 06-17-2011 10:34
Thanks Rick- I understand about 9 year olds--but mine are grandkids
88 PT40
817-475-3991
Date: Friday, June 17, 2011, 4:01 PM
-Rick in Ohio
88 PT40
817-475-3991
Rick in Ohio
Air Compressor Coolant Hoses - G - 06-23-2011 13:02
I think it would be neat if we could know what the Fire Department used. It
would benefit everyone.
> Rick in Ohio
> From: Ernie E
> Ã
