solar system - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: solar system (/showthread.php?tid=9427) |
solar system - jamiejbrandt - 06-29-2011 13:52 dose anyone know anything about solar systems for the RV I would like to put some type of system to charge my house batteries that are 48 volt 1990 wb40 Jamie Brandt Florida solar system - Kent - 06-30-2011 03:30 Jamie, I have an extensive solar system on my 98 LX. I have added onto a number of time over the years. We are "boondockers" and spend most of the winter in desert without hook-ups. Just what information did you need. Kent Johnson "odgeForum@yahoogroups.com, "jamiejbrandt" > > dose anyone know anything about solar systems for the RV > I would like to put some type of system to charge my house batteries that are 48 volt > 1990 wb40 > Jamie Brandt > Florida > solar system - G Boyd - 06-30-2011 05:16 You will need a regulator and probably a couple of panels depending on what wattage panel you buy. I think every RV should never leave the factory with out it. Boon docking right now and loving it! Batteries fully charged!
Gary Boyd On 29 June 2011 18:52, jamiejbrandt <"jamiejbrandt@yahoo.com"> wrote:
solar system - freewill2008 - 07-01-2011 13:17 For good information and top quality components check AMSolar.com They are in Springfield, Oregon but will ship anywhere. They have been RV Solar specialists since the 70's. Everything they sell is the newest generation high voltage gear that provides more charge per rated watt than garden variety systems. Ours has been on the bus for about 6 years without missing a beat. We dry camp most of the winter. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "jamiejbrandt" wrote: > > dose anyone know anything about solar systems for the RV > I would like to put some type of system to charge my house batteries that are 48 volt > 1990 wb40 > Jamie Brandt > Florida > solar system - Jamie - 07-06-2011 06:27 KENT I HAVE A 48 VOLT BATTERIE SYSTEM HOUSE BATTERIES IM WANTING TO KNOW IF I COULD ATTACH A SOLAR SYSTEM INTO THIS OR DOSE IT HAVE TO BE STAND ALONE AND IF ANYONE KNOWS WHERE TO GET THIS?? THANK YOU JAMIE JAMIEJBRANDT@... --- In WanderlodgeForum@yahoogroups.com, "Kent" > > > Jamie, > I have an extensive solar system on my 98 LX. I have added onto a number of time over the years. We are "boondockers" and spend most of the winter in desert without hook-ups. Just what information did you need. > Kent Johnson > > > "odgeForum@yahoogroups.com, "jamiejbrandt" > > > > dose anyone know anything about solar systems for the RV > > I would like to put some type of system to charge my house batteries that are 48 volt > > 1990 wb40 > > Jamie Brandt > > Florida > > > solar system - Don Bradner - 07-06-2011 07:08 I noted your reference to 48 volts in a prior post and assumed it was a mistake. What makes you think you have a 48-volt system? Stock on a 90 would be a single bank of 6 batteries serving both house and chassis. I've seen one where a separate engine bank was installed aftermarket, but the house remained 12 volts. Switching to 48 would require changing way too much stuff for no real gain. First guess is that you are seeing parallel but thinking series connections, but if I'm wrong I would love to hear about all of the changes made to make 48-volt work, along with the big question: Why? Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 7/6/2011 at 6:27 PM Jamie wrote: >KENT >I HAVE A 48 VOLT BATTERIE SYSTEM HOUSE BATTERIES IM WANTING TO KNOW IF I >COULD ATTACH A SOLAR SYSTEM INTO THIS OR DOSE IT HAVE TO BE STAND ALONE >AND IF ANYONE KNOWS WHERE TO GET THIS?? >THANK YOU >JAMIE >JAMIEJBRANDT@... > >--- In WanderlodgeForum@yahoogroups.com, "Kent" >> >> >> Jamie, >> I have an extensive solar system on my 98 LX. I have added onto a number >of time over the years. We are "boondockers" and spend most of the winter >in desert without hook-ups. Just what information did you need. >> Kent Johnson >> >> >> "odgeForum@yahoogroups.com, "jamiejbrandt" >> > >> > dose anyone know anything about solar systems for the RV >> > I would like to put some type of system to charge my house batteries >that are 48 volt >> > 1990 wb40 >> > Jamie Brandt >> > Florida >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > solar system - Jamie Brandt - 07-06-2011 09:12 Ya know Im not sure I will have to look again but Ithou-rttheywerein hooked up with thepositiveside going to thenegativeside what dose thatmien?? parallelor series?????
From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Wed, July 6, 2011 3:08:06 PM Subject: Re: [WanderlodgeForum] Re: solar system I noted your reference to 48 volts in a prior post and assumed it was a mistake. What makes you think you have a 48-volt system? Stock on a 90 would be a single bank of 6 batteries serving both house and chassis. I've seen one where a separate engine bank was installed aftermarket, but the house remained 12 volts. Switching to 48 would require changing way too much stuff for no real gain. First guess is that you are seeing parallel but thinking series connections, but if I'm wrong I would love to hear about all of the changes made to make 48-volt work, along with the big question: Why? Don Bradner 90 PT40 "Blue Thunder" My location: www.bbirdmaps.com/user2.cfm?user=1 On 7/6/2011 at 6:27 PM Jamie wrote: >KENT >I HAVE A 48 VOLT BATTERIE SYSTEM HOUSE BATTERIES IM WANTING TO KNOW IF I >COULD ATTACH A SOLAR SYSTEM INTO THIS OR DOSE IT HAVE TO BE STAND ALONE >AND IF ANYONE KNOWS WHERE TO GET THIS?? >THANK YOU >JAMIE >"JAMIEJBRANDT%40YAHOO.COM" > >--- In "WanderlodgeForum%40yahoogroups.com", "Kent" >> >> >> Jamie, >> I have an extensive solar system on my 98 LX. I have added onto a number >of time over the years. We are "boondockers" and spend most of the winter >in desert without hook-ups. Just what information did you need. >> Kent Johnson >> >> >> ""odgeForum%40yahoogroups.com", "jamiejbrandt" >> > >> > dose anyone know anything about solar systems for the RV >> > I would like to put some type of system to charge my house batteries >that are 48 volt >> > 1990 wb40 >> > Jamie Brandt >> > Florida >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > solar system - Gary Smith - 07-06-2011 12:34 If they are 6v batteries, you likely have pairs connected into 12's, then they are on parallel with the output being at 12 volts. Gary SOB Sent from Gary's iPhone
On Jul 6, 2011, at 2:12 PM, Jamie Brandt <"jamiejbrandt@yahoo.com"> wrote:
solar system - Don Bradner - 07-06-2011 18:43 Like Gary said, it might be 6-volts in series-parallel. That's what I changed mine to. In any case, throw a voltmeter on the output and see if you can find more than 12V (13.4V) anywhere. On 7/6/2011 at 2:12 PM Jamie Brandt wrote: >Ya know Im not sure I will have to look again but I thou-rt they were in >hooked >up with the positive side going to the negative side >what dose that mien?? >parallel or series????? > > >________________________________ >From: Don Bradner >To: WanderlodgeForum@yahoogroups.com >Sent: Wed, July 6, 2011 3:08:06 PM >Subject: Re: [WanderlodgeForum] Re: solar system > > >I noted your reference to 48 volts in a prior post and assumed it was a >mistake. > >What makes you think you have a 48-volt system? > >Stock on a 90 would be a single bank of 6 batteries serving both house and >chassis. I've seen one where a separate engine bank was installed >aftermarket, >but the house remained 12 volts. Switching to 48 would require changing >way too >much stuff for no real gain. > >First guess is that you are seeing parallel but thinking series >connections, but >if I'm wrong I would love to hear about all of the changes made to make >48-volt >work, along with the big question: Why? > >Don Bradner >90 PT40 "Blue Thunder" >My location: http://www.bbirdmaps.com/user2.cfm?user=1 >On 7/6/2011 at 6:27 PM Jamie wrote: > >>KENT >>I HAVE A 48 VOLT BATTERIE SYSTEM HOUSE BATTERIES IM WANTING TO KNOW IF I >>COULD ATTACH A SOLAR SYSTEM INTO THIS OR DOSE IT HAVE TO BE STAND ALONE >>AND IF ANYONE KNOWS WHERE TO GET THIS?? >>THANK YOU >>JAMIE >>JAMIEJBRANDT@... >> >>--- In WanderlodgeForum@yahoogroups.com, "Kent" >>> >>> >>> Jamie, >>> I have an extensive solar system on my 98 LX. I have added onto a number >>of time over the years. We are "boondockers" and spend most of the winter >>in desert without hook-ups. Just what information did you need. >>> Kent Johnson >>> >>> >>> "odgeForum@yahoogroups.com, "jamiejbrandt" >>> > >>> > dose anyone know anything about solar systems for the RV >>> > I would like to put some type of system to charge my house batteries >>that are 48 volt >>> > 1990 wb40 >>> > Jamie Brandt >>> > Florida >>> > >>> >> >> >> >> >>------------------------------------ >> >>Yahoo! Groups Links >> >> >> |
