Water valve - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water valve (/showthread.php?tid=9436) |
Water valve - jepetto58 - 07-08-2011 02:33 Ralph and Ernie, Man, you guys are GOOD! That is exactly what it was. I would have never thought that is what it could be. There was a extra(disconnected) sporlan valve running along the side wall of the bus that I removed the diaphram from and changed it out. Worked good. I could see through a clear filter housing before the pump motor that I was getting a lot of air in the system. Anyhow, I am going to order two new diaphrams and 1 of the coil and repair both. I am not sure what that other copper line goes to but would like to get it fixed. It has been disconnected and capped off. Thank you both for the help. That saved me a lot of time. Jeff Lawrence Panama City Beach Water valve - Ernie Ekberg - 07-08-2011 04:12
