3208 Starter Source - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 3208 Starter Source (/showthread.php?tid=9452) |
3208 Starter Source - freewill2008 - 07-24-2011 12:46 Anyone know of a good source out west to pick up a new or rebuilt 3208 starter? My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. Bob Griesel '84 FC31 WLII 3208 Starter Source - Fred Hulse - 07-24-2011 13:31 Hi Bob,
The little info I have says that part number is very common on Cat engines
I use this website a lot when I need information.
They show Caterpillar numbers to Delco numbers and a wealth of info.
Iââ¬â¢m not certain how you source stuff,but any good truck electric should supply it,even NAPA
Fred Hulse Morristown,Arizona 97 WLWB41 3208 Starter Source - freewill2008 - 07-24-2011 16:06 Thanks Fred! --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Hi Bob, > > The little info I have says that part number is very common on Cat engines > http://www.dixie-electric.com/catalog/DixiePLGR4555Series.pdf > > I use this website a lot when I need information. > They show Caterpillar numbers to Delco numbers and a wealth of info. > > Iââ¬â¢m not certain how you source stuff,but any good truck electric should supply it,even NAPA > > Fred Hulse > Morristown,Arizona > 97 WLWB41 > 3208 Starter Source - xz3kg7 - 07-26-2011 15:06 Hi Bob, I'm not sure where you are located, but I had mine rebuilt last year here in Dallas. I found the starter place that I've used for other starters could handle the big Cat starter. Anyway, I can look up the contact information if something here helps you. Otherwise you might find out like I did that your local starter rebuilder can help you out. alan 87FC35 in Dallas --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > Anyone know of a good source out west to pick up a new or rebuilt 3208 starter? My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. > > Bob Griesel '84 FC31 WLII > 3208 Starter Source - freewill2008 - 07-26-2011 17:22 Thanks Alan. NAPA fixed me up with a reman. Its in and working fine. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" > > Hi Bob, > > I'm not sure where you are located, but I had mine rebuilt last year here in Dallas. I found the starter place that I've used for other starters could handle the big Cat starter. > > Anyway, I can look up the contact information if something here helps you. Otherwise you might find out like I did that your local starter rebuilder can help you out. > > alan > 87FC35 in Dallas > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > > > Anyone know of a good source out west to pick up a new or rebuilt 3208 starter? My service sheet says the original was a Delco 1114826. I can find that starter with a Web search, but the source is on the east coast and says it is the starter for some kind of 3208-powered industrial equipment. > > > > Bob Griesel '84 FC31 WLII > > > |
