Add on air compressor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Add on air compressor (/showthread.php?tid=9506) |
Add on air compressor - DonS - 10-11-2011 09:39 I had a small sears pancake compressor that I carried with me but it quit making air. I am going to get a new compressor to take a with me & I was wandering if it would be ok to take the tanks off & use the compressor by itself. I have a good place to plumb it in before the air dryer. I don't like taking up the extra room for the tanks. They are twin tanks & the compressor has a 200psi which would be good to air up the coach. Don Spithaler 89 SP 36 Butler, PA Add on air compressor - BG - 10-11-2011 11:01 That is how I would do it. A check valve should be used between the compressor and your plumb-in point. Bob Griesel 84 FC31 WLII WA I had a small sears pancake compressor that I carried with me but it quit making air. I am going to get a new compressor to take a with me & I was wandering if it would be ok to take the tanks off & use the compressor by itself. I have a good place to plumb it in before the air dryer. I don't like taking up the extra room for the tanks. They are twin tanks & the compressor has a 200psi which would be good to air up the coach. Don Spithaler 89 SP 36 Butler, PA ------------------------------------ Yahoo! Groups Links http://groups.yahoo.com/group/WanderlodgeForu m/ http://groups.yahoo.com/group/WanderlodgeForu m/join (Yahoo! ID required) WanderlodgeForum-fullfeatured@yahoogroups.com WanderlodgeForum-unsubscribe@yahoogroups.com Add on air compressor - Donald Spithaler - 10-11-2011 11:15 Bob, Â Â I wouldn't need a gauge on that compressor with it working with the air governor would I ? Don Spithaler 89 SP 36' Butler, PA Â On Tue, Oct 11, 2011 at 7:01 PM, BG <"sundance101@comcast.net"> wrote:
Add on air compressor - BG - 10-11-2011 12:38 The gauge is useful so you know what the aux air system is doing, but it won't control the compressor. If the compressor doesn't already have one, you need a pressure switch that can be set to just below the normal bus air pressure which is probably 125PSI.
Bob, I wouldn't need a gauge on that compressor with it working with the air governor would I ?Don Spithaler 89 SP 36' Butler, PA On Tue, Oct 11, 2011 at 7:01 PM, BG <"sundance101@comcast.net"> wrote:
Add on air compressor - D E BARNES - 10-11-2011 14:28 The single comment I would make is to be aware of the compressor's CFM. Several of the modern box store cheap compressors will build plenty of PSI, but the supply CFM is so low that it might take days to air a bus tire. A friend just bought one with 0.85 CFM. It runs his brad nailer just fine but struggles airing his trailer tires to 32 PSI. Donn 1990 40-WB Alvarado, TX On 10/11/11 4:39 PM, "DonS" > I had a small sears pancake compressor that I carried with me but it quit > making air. I am going to get a new compressor to take a with me & I was > wandering if it would be ok to take the tanks off & use the compressor by > itself. I have a good place to plumb it in before the air dryer. I don't like > taking up the extra room for the tanks. They are twin tanks & the compressor > has a 200psi which would be good to air up the coach. > Don Spithaler > 89 SP 36 > Butler, PA > > > > ------------------------------------ > > Yahoo! Groups Links > > > Add on air compressor - G Boyd - 10-11-2011 16:39 You want to make sure your not pushing 200 PSI throughout the bus. That would not be a positive effect. You need to have it governed to about 120 PSI and the compressor your purchasing should have a governor on it. Sometimes they are adjustable. I would not just install it without a governor. On 11 October 2011 14:39, DonS <"dspithaler@gmail.com"> wrote:
Add on air compressor - Donald Spithaler - 10-12-2011 01:23 Thanks guys some good advice. I'll check the cfm on it. It is a emglo that supports 4 air nailers. It also has oil in it which my old sears didn't have it. Don Spithaler 89 SP 36' Butler, PA. Â Â Â Â On Wed, Oct 12, 2011 at 12:39 AM, G Boyd <"gboyd007@gmail.com"> wrote:
Add on air compressor - billpatty@... - 10-12-2011 01:24 Hi Don, Yes you can use just the compressor head, while using the Bus as an air tank, But follow the previous posts and besure to have a regulator and a gage at the aux compressor, Do not exceed 120/125 PSi to the bus, When usung this Aux compressor I would monitor the gages for proper operation. Bill Pape 88 FC --- In WanderlodgeForum@yahoogroups.com, Donald Spithaler wrote: > > Thanks guys some good advice. I'll check the cfm on it. It is a emglo that > supports 4 air nailers. It also has oil in it which my old sears didn't have > it. > Don Spithaler > 89 SP 36' > Butler, PA. > > On Wed, Oct 12, 2011 at 12:39 AM, G Boyd > > > ** > > > > > > You want to make sure your not pushing 200 PSI throughout the bus. That > > would not be a positive effect. You need to have it governed to about 120 > > PSI and the compressor your purchasing should have a governor on it. > > Sometimes they are adjustable. I would not just install it without a > > governor. > > > > > > On 11 October 2011 14:39, DonS > > > >> ** > >> > >> > >> I had a small sears pancake compressor that I carried with me but it quit > >> making air. I am going to get a new compressor to take a with me & I was > >> wandering if it would be ok to take the tanks off & use the compressor by > >> itself. I have a good place to plumb it in before the air dryer. I don't > >> like taking up the extra room for the tanks. They are twin tanks & the > >> compressor has a 200psi which would be good to air up the coach. > >> Don Spithaler > >> 89 SP 36 > >> Butler, PA > >> > >> > > > > > Add on air compressor - G - 10-12-2011 02:28 Hey Bob, Please send me your email addy. I am never sure if I am seeing the correct info on this forum. Cheers Gary --- In WanderlodgeForum@yahoogroups.com, "BG" > > That is how I would do it. A check valve > should be used between the compressor and > your plumb-in point. > Bob Griesel > 84 FC31 WLII WA > > I had a small sears pancake compressor that I > carried with me but it quit making air. I am > going to get a new compressor to take a with > me & I was wandering if it would be ok to > take the tanks off & use the compressor by > itself. I have a good place to plumb it in > before the air dryer. I don't like taking up > the extra room for the tanks. They are twin > tanks & the compressor has a 200psi which > would be good to air up the coach. > Don Spithaler > 89 SP 36 > Butler, PA > > > > ------------------------------------ > > Yahoo! Groups Links > > http://groups.yahoo.com/group/WanderlodgeForu > m/ > > http://groups.yahoo.com/group/WanderlodgeForu > m/join > (Yahoo! ID required) > > WanderlodgeForum-fullfeatured@yahoogroups.com > > WanderlodgeForum-unsubscribe@yahoogroups.com > |
