110 v motor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 110 v motor (/showthread.php?tid=955) |
110 v motor - krminyl@... - 06-29-2005 07:18 Dave, I probably don't know what I'm talking about, but I had heard (on this forum a long while back) that the genset radiator electric fan motor is 220v (at least on the 1986). I'm fortunate to say that mine is ok, and have never had to even look at it, but am I so screwed up that someone can tell me that I'm crazy?? I would certainly hope that any decent electrician could tell if the motor of 110v or 220v (an electrician I am not). Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] 110 v motor - David Heibult - 06-29-2005 10:23 I put a new 1/4 hp electric 110v motor on my generator for the second raditor .I had a electrican wire it up/ but now the problem. It will only run for a couple of minutes then overheats and dies.You let it set for half hour and it will run again. the only diff I saw was when we wired up the Cap. we went with 2 wires from the motor instead of one like the old motor .on the old motor the white wire went to the cap and the other white wire went from the source went to the other side of the cap. now the electrican wired both brown wires to the cap and the white wires from the motor and the white wire from the source he wird direct. my understanding the cap comes only in play when you first start the motor then doesen't it drop off line from then on.I'm wondering if the cap is running all the time and overheating the motor.Dave 91WLPT 40 & 82 FC 35 110 v motor - randydupree - 06-29-2005 11:34 thats the first thing to check! 110 or 230 volt!!,kevin is right! randy93wb ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 29, 2005 7:18 PM Subject: Re: [WanderlodgeForum] 110 v motor Dave, I probably don't know what I'm talking about, but I had heard (on this forum a long while back) that the genset radiator electric fan motor is 220v (at least on the 1986). I'm fortunate to say that mine is ok, and have never had to even look at it, but am I so screwed up that someone can tell me that I'm crazy?? I would certainly hope that any decent electrician could tell if the motor of 110v or 220v (an electrician I am not). Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] 110 v motor - David Heibult - 06-29-2005 13:19 Kevin. When we took off the old motor we replaced it in kind. 110v 3.70 amp.Dave 91 WLPT 40 & 82 FC 35 >From: krminyl@... >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] 110 v motor >Date: Wed, 29 Jun 2005 19:18:52 EDT > [Non-text portions of this message have been removed] 110 v motor - Wilhelmus Schreurs - 06-29-2005 14:51 David: You are correct in saying that the capacitor is only there for starting purposes. I could not understand the wiring which you were explaining. Generally on a motor of this rating, there should be three wires, hot, neutral and ground. (green, black and white) The capacitor should already be connected in the circuit as well as the centrifugal switch. It is possible though to have additional wires if it were torn right apart. You would have one coming from the centrifugal switch and two more from the capacitor. If this were the case you would have to hook up all of the wires correctly. In this case, centrifugal switch to one side of the capacitor, the other side of the capacitor with one (white) wire from motor to neutral (white), and the other wire to hot (black), and of course the ground wire (green) Hope this helps. Bill --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
