Power selector switch - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Power selector switch (/showthread.php?tid=9568) |
Power selector switch - Rex Puckett - 03-13-2012 10:10 Does anyone know how to remove the AC power selector switch located to the left of the door beside the passenger seat. My switch was damaged by a power surge and is almost impossible to switch. I have crawled under the wheel well and removed the insulation on the enclosure box and can see no way to access. Anyone ever removed this switch? Any help appreciated 85 36Pt Power selector switch - sundance101@... - 03-13-2012 11:20 If BB used the same transfer switch enclosure on the PT as the FC, the top comes off the enclosure with a row of phillips head screws.
Bob Griesel '84 FC31 WLII WA From: "Rex Puckett" Sent: Tuesday, March 13, 2012 2:10:16 PM Subject: [WanderlodgeForum] Power selector switch Does anyone know how to remove the AC power selector switch located to the left of the door beside the passenger seat. My switch was damaged by a power surge and is almost impossible to switch. I have crawled under the wheel well and removed the insulation on the enclosure box and can see no way to access. Anyone ever removed this switch? Any help appreciated 85 36Pt ------------------------------------ Yahoo! Groups Links <*> To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ <*> Your email settings: Individual Email | Traditional <*> To change settings online go to: http://groups.yahoo.com/group/WanderlodgeForum/join (Yahoo! ID required) <*> To change settings via email: WanderlodgeForum-digest@yahoogroups.com WanderlodgeForum-fullfeatured@yahoogroups.com <*> To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com <*> Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/ Power selector switch - Rex Puckett - 03-13-2012 15:38 below floor or above? There are no visible screws under the lift up door and I could not see any below floor. Looks as if the enclosure is between the metal and plywood floor. I am thinking that I will have to remove the carpet and plywood?????? Rex Puckett '85 PT36 --- In WanderlodgeForum@yahoogroups.com, sundance101@... wrote: > > If BB used the same transfer switch enclosure on the PT as the FC, the top comes off the enclosure with a row of phillips head screws. > > Bob Griesel '84 FC31 WLII WA > > ----- Original Message ----- > From: "Rex Puckett" > Sent: Tuesday, March 13, 2012 2:10:16 PM > Subject: [WanderlodgeForum] Power selector switch > > Does anyone know how to remove the AC power selector switch located to the left of the door beside the passenger seat. My switch was damaged by a power surge and is almost impossible to switch. I have crawled under the wheel well and removed the insulation on the enclosure box and can see no way to access. Anyone ever removed this switch? Any help appreciated > > 85 36Pt > > > > ------------------------------------ > > Yahoo! Groups Links > Power selector switch - Wilhelmus Schreurs - 03-14-2012 15:23
Power selector switch - Rex Puckett - 03-15-2012 05:48 Removed plate and found screws, will remove as time allows. Thank you for your help. Do you know if switches are repairable? Who repairs? If not repairable, a source for the switch? Thanks again! Rex Puckett, 85 PT36 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Rex: > You are correct. You will not see any screws on top. I have not taken my switch apart but have worked on many typical of these. > There should be a plate with the words of shore, 50 amp etc, on it, this could be moved to the top or bottom and should pop out. Underneath you will find the screws Bob is talking about. > If this does not work, I will be going to my coach tomorrow and have a look. > > Bill > 1988 40WB XXV "Anniversary Special Edition" > Kitimat, B.C. Canada eh > Power selector switch - Ralph - 03-15-2012 05:51 Y Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "Rex Puckett" Date: Thu, 15 Mar 2012 16:48:34 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Power selector switch Removed plate and found screws, will remove as time allows. Thank you for your help. Do you know if switches are repairable? Who repairs? If not repairable, a source for the switch? Thanks again! Rex Puckett, 85 PT36 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Rex: > You are correct. You will not see any screws on top. I have not taken my switch apart but have worked on many typical of these. > There should be a plate with the words of shore, 50 amp etc, on it, this could be moved to the top or bottom and should pop out. Underneath you will find the screws Bob is talking about. > If this does not work, I will be going to my coach tomorrow and have a look. > > Bill > 1988 40WB XXV "Anniversary Special Edition" > Kitimat, B.C. Canada eh > ------------------------------------ Yahoo! Groups Links Power selector switch - Ralph - 03-15-2012 05:53 Sorry a mis sent reply Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "Rex Puckett" Date: Thu, 15 Mar 2012 16:48:34 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Power selector switch Removed plate and found screws, will remove as time allows. Thank you for your help. Do you know if switches are repairable? Who repairs? If not repairable, a source for the switch? Thanks again! Rex Puckett, 85 PT36 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Rex: > You are correct. You will not see any screws on top. I have not taken my switch apart but have worked on many typical of these. > There should be a plate with the words of shore, 50 amp etc, on it, this could be moved to the top or bottom and should pop out. Underneath you will find the screws Bob is talking about. > If this does not work, I will be going to my coach tomorrow and have a look. > > Bill > 1988 40WB XXV "Anniversary Special Edition" > Kitimat, B.C. Canada eh > ------------------------------------ Yahoo! Groups Links Power selector switch - Wilhelmus Schreurs - 03-16-2012 05:19
