throttle cable for '87 FC 35' - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: throttle cable for '87 FC 35' (/showthread.php?tid=9572) |
throttle cable for '87 FC 35' - dixonsally - 03-21-2012 12:45 Does anyone have a source for the swaged fitting on the air end of the throttle cable, or a complete cable? Current one is hanging up on housing lining. I can get new Morse cable and threaded engine end no problem. No one knows anything about the swaged fitting with nut at the other end. Jean Eichenlaub San Diego, CA throttle cable for '87 FC 35' - rick87fc35 - 03-22-2012 00:49 Mike Hohnstein helped me with my Throttle Cable when it broke, check in with him and see if he can help. Here is is member info page over on the WOG site: http://www.wanderlodgeownersgroup.com/forums/member.php?u=236 Rick Brink 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, "dixonsally" > > Does anyone have a source for the swaged fitting on the air end of the throttle cable, or a complete cable? Current one is hanging up on housing lining. I can get new Morse cable and threaded engine end no problem. No one knows anything about the swaged fitting with nut at the other end. > > Jean Eichenlaub > San Diego, CA > throttle cable for '87 FC 35' - mbulriss - 03-22-2012 02:35 Hi Jean, If you look in the Parts Database on the forum, and search on "throttle cable", there are three sources of info on the throttle cable. The third entry seems to be a source for that unique end. It appears that the cable has to be built and a source was listed as Midwest Control Products at http://www.midwestcontrol.com/240.php http://autos.groups.yahoo.com/group/WanderlodgeForum/database?query=throttle+cable&submit=Search&method=reportRows&tbl=4 Also, in the database section of the forum is a Member-to-Member listing and Mike Hohnstein has a contact entry listed there also at http://autos.groups.yahoo.com/group/WanderlodgeForum/database?method=reportRows&tbl=1&sortBy=1&sortDir=down&start_at=80 Hope this helps. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "dixonsally" > > Does anyone have a source for the swaged fitting on the air end of the throttle cable, or a complete cable? Current one is hanging up on housing lining. I can get new Morse cable and threaded engine end no problem. No one knows anything about the swaged fitting with nut at the other end. > > Jean Eichenlaub > San Diego, CA > |
