Installed new batteries - have a fuse question. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Installed new batteries - have a fuse question. (/showthread.php?tid=960) |
Installed new batteries - have a fuse question. - krminyl@... - 06-30-2005 22:34 John, Glad you got the new batts. Those suckers are heavy! Didn't realize how heavy they were until I put all six in the back of my pickup. I didn't quite understand your comment about the battery caps from Exide...could you possibly report your comment? Can't help you on the fuse issue...the only fuses I'm aware of in my engine compartment are the ones I put there. My burglar alarm fuse is under my dash... Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] Installed new batteries - have a fuse question. - Adria Haynes - 07-01-2005 01:27 I wound up getting the Batteries from Sams club that I asked about. The deal to lock and unlock the water caps says Exide in it, BTW. Thanks for the positive feeedbacks about getting them. Anyways, inside the battery compartment of my 1980 35FC, there is a small 4 place fuse panel with two on top and two more right below them. The top two are 20 amp ones and the bottom two are both 15. The upper left one was blown. I looked in the diagram sheets in the books from the blue box, to see what it went to, and the info doesn't jive. The drawings claim that my bus only has a three panel fuse box there - that there are (2) 2 amp fuses and a single 20 amp fuse - all in a vertical row arrangement. It calls out the 20 as being for the burgler alarm system. With my arrangement being so different AND having more than one 20 amp fuse, I know not to trust it. Does anybody with a similar vintage bus have this configuration and can you please tell me what "thing" is blowing that fuse. Incidently, after installing the new batteries, I hit the key and have never had the bus start faster than that in my 15 months of ownership. Any help is appreciated, John Installed new batteries - have a fuse question. - Adria Haynes - 07-01-2005 04:00 Instead of having three seperate caps - they have one mechanism that unlocks all 3 of the caps and holds them at the same time - and THAT thing reads Exide on it. --- In WanderlodgeForum@yahoogroups.com, krminyl@a... wrote: > John, > > Glad you got the new batts. Those suckers are heavy! Didn't realize how > heavy they were until I put all six in the back of my pickup. I didn't quite > understand your comment about the battery caps from Exide...could you possibly > report your comment? > > Can't help you on the fuse issue...the only fuses I'm aware of in my engine > compartment are the ones I put there. My burglar alarm fuse is under my > dash... > > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] |
