Re; Sluggish 8V - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Re; Sluggish 8V (/showthread.php?tid=9689) |
Re; Sluggish 8V - Patticake - 11-07-2012 12:30 Even after ckecking all other factors, I would have the valves and injectors checked. I had mine done at 200k, and while the valves were good, the injectors needed adjusting. Now has more getup and go with less smoke. Steve Gureasko 90WBWL40 "Jus Chillin" Ponchatoula, La. Re; Sluggish 8V - Michael Bulriss - 11-07-2012 14:18 From experience, I would check the exhaust to turbo pipes. Sounds like one of them has developed a leak if it is totally gutless at take off but seems ok when up to speed. Look carefully at the flange areas inside the clamps that hold them to the exhaust manifolds. You may have to loosen the clamps and remove the pipes to check the flanges. A good truck parts house can supply flange extensions to replace the bad ones if that is it. The pipes themselves are VERY hard to locate, even used. Don't ask how I know. LOL Let us know what the solution is. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone
On Nov 7, 2012, at 6:30 PM, "Patticake" <"sgureasko@gmail.com"> wrote:
Re; Sluggish 8V - Don Bradner - 11-07-2012 15:18 So, all of the rest of you with 8V92s are telling us they practically hop off the line? On 11/7/2012 at 8:18 PM Michael Bulriss wrote: >From experience, I would check the exhaust to turbo pipes. Sounds like >one of them has developed a leak if it is totally gutless at take off but >seems ok when up to speed. Look carefully at the flange areas inside the >clamps that hold them to the exhaust manifolds. You may have to loosen the >clamps and remove the pipes to check the flanges. A good truck parts >house can supply flange extensions to replace the bad ones if that is it. >The pipes themselves are VERY hard to locate, even used. Don't ask how I >know. LOL > >Let us know what the solution is. > >Mike Bulriss >1991 WB40 "Texas Minivan" >San Antonio, TX > >Sent from my iPhone > >On Nov 7, 2012, at 6:30 PM, "Patticake" <sgureasko@...> wrote: > >> Even after ckecking all other factors, I would have the valves and >injectors checked. I had mine done at 200k, and while the valves were >good, the injectors needed adjusting. Now has more getup and go with less >smoke. >> >> Steve Gureasko >> 90WBWL40 "Jus Chillin" >> Ponchatoula, La. >> >> Re; Sluggish 8V - Wilhelmus Schreurs - 11-09-2012 00:00
Re; Sluggish 8V - Michael Bulriss - 11-09-2012 05:57
