LXi: Duralite Charge Air Cooler - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Chassis (/forumdisplay.php?fid=23) +--- Thread: LXi: Duralite Charge Air Cooler (/showthread.php?tid=9753) |
LXi: Duralite Charge Air Cooler - davidbrady - 04-29-2013 12:36 Folks, Some time ago I worked with Duralite (Calgary Alberta, Canada) to produce a Charge Air Cooler (CAC) for our LXi's. The part number is: BLUDAC-350B. Duralite has a patent on a silicon grommet they use to connect the tubes to the tank. The CAC is available thru your local Detroit Diesel Allison Service Center. |
