LXi Chassis Part Numbers - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Chassis (/forumdisplay.php?fid=23) +--- Thread: LXi Chassis Part Numbers (/showthread.php?tid=9767) |
LXi Chassis Part Numbers - davidbrady - 05-02-2013 12:07 Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page: 1) Entryway air step norgren valve: The original equipment Norgren 5/2 solenoid piloted valve is superseded by Norgren part number V61R511AA312JB available at Carolina Fluid Components, Charlotte, NC 704-588-6101. 2) Drive Axle MGM Brake Chamber I put new brake chambers on my drive axle. The original part, MGM 4131213, is no longer available and has been superseded by MGM Magnum Performance Plus part number: MGM: MJS3028ET051, The new part is a long stroke (3") model with 300# of additional parking brake force. Both new and old are piston style chambers. 3) Chelsea PTO Spline Grease The spline grease Chelsea specifies is part number 379831 available at Fleetpride, Florig, and National Fleet. An even better choice is Klueber grease, Microlube GL 261, available here at Advanced Machine and Lubrications Services. 4) Hayden Hydraulic Fan Cooler Drawings can be found in our trusty Document Library at Document Library->Models->LXi. Hayden part numbers: 027026: cooler core 017048: fan plate 025576: fan assy 016945: cabinet All available at most hydraulics supply vendors. Here in Charlotte NC we have: a) Berendsen: 704-588-7723; $540.00 for 027026; 3 to 4 weeks, b) Livingston & Haven: 704-525-7910; $340 for 027026; 3 to 4 weeks, c) Sunsource: (800) 228-4831 (Pays to shop around). 5) Hydraulic Fan Pump and PTO Please see this thread: Chassis Forum: LXi-and-WideBody-PTO-Pump-Splines. 6) Stainless Steel Exhaust System and Muffler Please see this thread: Chassis Forum: Stainless-Steel-Exhaust-95-WB-thru-LXi. 7) Duralite Charge Air Cooler Please see this thread: Chassis Forum: LXi-Duralite-Charge-Air-Cooler 8) LXi Slide Seal Part Numbers (Brady Seal) Please see this thread: LX-and-LXi-Slide-Seal-Part-Numbers-Brady-Seal. 9) LXi Ridewell Suspension Air-Springs Please see this thread: LXi-Ridewell-Susp-and-Air-Spring-Part-Numbers. 10) Koni Shocks Steer (adjustable) 90-2497SP1, adjust one turn from full soft, Drive (FSD, non-adjustable) 9005-1025, and Tag (FSD, non-adjustable) 8805-1010. 11) Brake Shoes and Drums Please see this thread: Steer, Drive, Tag Axle Shoes and Drums. RE: LXi Chassis Part Numbers - DOSZORROS - 05-02-2013 18:43 (05-02-2013 12:07)davidmbrady Wrote: Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page: LXI engine door latching gas spring: Orr & Orr, Inc. Stock no. H9516-100 (100 lb.) RE: LXi Chassis Part Numbers - davidbrady - 08-29-2013 10:07 Thank you Chuck Millsap for this extensive list of LXi belt and filter part numbers. ![]() (08-27-2013 17:49)cmillsap Wrote: Here's a list of belt and filter part #s that I have compiled from several sources for an LXI. LXI Filters & Belts Part #s LXi Air Filter Part #s ECOLITE 546895 WIX ECO-SM 46895 Baldwin # PA2723 Donaldson # P537449 Fleetgard # AH8505 Hastings # AF2269 Farr # 62891-3 ---------------------------------------------------------------------- LXi Oil & Fuel Filters Part #s Detroit Diesel S60 500 HP- ECU DD111 Oil capacity = 39 Quarts Multi-Grade 15-40 Oil Filter #1 = FG: LF3620 or equivalent Oil Filter #2 = FG: LF3620 or equivalent Fuel Filter #3 = FG: FF5206 or equivalent Fuel Filter #4 = FG: FS20203 or equivalent Coolant Filter = Specific for Coolant Type =Use DDF60 with Power Cool Plus Coolant ---------------------------------------------------------------------- LXi -DD S60 Serpentine Belt Part #s Outside Circumference (in) : 72.632" Top Width (in) : 1.647" Part Number: NBH 25120720 Product Line: NAPA Belts & Hoses DAYCO 5120720 Metric 12PK1830 Gates K120720 Napa 25-120720 Napa 25120720 Goodyear 4120720 Bando 12PK1828 VB Supply 720K12 K DD 23521337 ---------------------------------------------------------------------- LXi- DDS60 A/C Compressor Drive Belts Gates GT17672 Matched Pair (Discontinued) Gates 9710 Single Belt (2 Required) ---------------------------------------------------------------------- LXi Hydraulic Oil Reservoir Filter Part #s • BALDWIN PT8487 • DONALDSON P55-0698 • FRAM C7058 • NAPA 7196 • WIX 57196 ---------------------------------------------------------------------- Powertech 15KW Filters & Belt Part #s Fuel filter; • BB #3970860 • NAPA #3390 • Powertech #08FF081 • Kubota #70000-43081 Oil filter; • BB #3970878 • NAPA #1515 • Baldwin #B5 • Powertech #01FO091 • WIX #51068 • Kubota #70000-32091 Air filter; • BB #3838158 • Donaldson #ECB05-5001 • Powertech #04FA080 • Kubota #70000-11080 Fan Belt; • With Idler Pulley; • Powertech #03BF9447 $22.97 • Kubota #15469-97010 or #15469-73010 (not specified idler or[/u] alternator) • NAPA #XL 25-9447 Dimensions; 31/64"X44-7/8" (12.5/13mm X 1140mm) • With Alternator; • Powertech #03BF0203 ---------------------------------------------------------------------- LXi Allison 4060 Transmission Filter Part # Allison Kit # 29548988 RE: LXi Chassis Part Numbers - cmillsap - 09-06-2013 23:42 (08-29-2013 10:07)davidbrady Wrote: Thank you Chuck Millsap for this extensive list of LXi belt and filter part numbers. RE: LXi Chassis Part Numbers - rrueckwald - 11-08-2013 21:49 (05-02-2013 12:07)davidbrady Wrote: Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page: Any information on the correct air springs for the bay doors and the engine cover door? I seem to have a mish-mash on mine and would like a little more force from the left engine cover. Mine may have some wrong parts. RE: LXi Chassis Part Numbers - davidbrady - 11-09-2013 12:34 Hi Ron, Engine deck lid locking gas spring: FAL22, and the ball studs. Engine compartment side doors (radiator/CAC and battery): Stabilus 280N, 0703IM, 295400 Under Slide: Bay door 1 and 2: FAN22E, 80 lb Bay door 3: AVM SE1500M, 80 lb Pantograph doors: (from the BB parts catog): 200 lb, Length: 11.81" to 19.69", small end. RE: LXi Chassis Part Numbers - rrueckwald - 11-10-2013 00:47 (11-09-2013 12:34)davidbrady Wrote: Hi Ron, Many thanks, David. It is one of the many "next" projects. That helps. RE: LXi Chassis Part Numbers - al perna - 08-18-2016 15:58 are the king pin and tie rod ends here somewhere and I just missed them ? |
