Coolant change - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Coolant change (/showthread.php?tid=978) |
Coolant change - samax8 - 07-04-2005 09:49 Any advice on changing and flushing cooling system in 82FC. I have not been under yet for a close look but will draining the radiator also drain all the coolant from lines running to the back for hot water and chassis heat? Any suggestion on flushing system or should I just drain and refill with new coolant. I plan on using Cat antifreeze and hopefully can determine the exact capacity. Thanks Bill 82FC33 |
