1980 33' Newbie with Questions and a funny story. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1980 33' Newbie with Questions and a funny story. (/showthread.php?tid=982) |
1980 33' Newbie with Questions and a funny story. - vabroker1 - 07-05-2005 13:57 I am a new owner of a 1980 33'. Fairfax, VA With loads of questions. Would love to hear from anyone. 1. I have a Redline Motor Generator in the front pass. side storage. It appears to not be working. It has power cord that is plugged into it. After being repaired will the power cord power any of the outlets? 2. In front of the pass. front seat is a red switch. It pulls 15 amps. But I have no idea what it runs. Help? 3. The blowers for each of the heaters do not work. Front sofa, dining area, and bedroom. These are the ones that run off engine heat. Any idea where the fuse is for these? 4. I had no hot water in the shower. Found the balance valve stuck. Can I work it with some WD40 a little and replace or should I just replace the balance valve. 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." But the Ice Maker is not plugged into it. 6. My gas gauge works great except when I switch to diesel. Then it pegs to Empty like it is shorted. It is not the sending unit. Other most likely causes? Now for my funny story. First I have never driven a BlueBird before this trip. I bought the Bird from an individual in Chicago. Flew to Chicago and drove 750 miles to Fairfax, VA. About 150 miles into the trip it was snowing and raining hard. I decided to make a stop to get gas and rest. As I was waiting in line to get gas the air horn would start to blow ever so lightly. I would tap the horn button, turn of the engine, and bang on the dash. After a few minutes it stopped blowing. I was so embarrassed I went to a different gas station. Once again as I was waiting in line at a truck stop to get gas, I could hear the air horn blowing again, sometimes softly, other times full blow. Finally after several minutes it would stop. So I figured it was a rain related short. About 650 miles in the trip my legs were getting cramped so I tried to stretch them when I was surprised with a full blow from the air horn. That's when I found the Air Horn Valve on the floor. My short was in my leg. 1980 33' Newbie with Questions and a funny story. - Curt Sprenger - 07-05-2005 14:14 I can't help with the questions. But I have felt dumb before. I had the same issue with the AIR HORN. You are not alone. Welcome to the Forum! Curt Sprenger â87PT38, Anaheim, Calif. vabroker1 wrote: > I am a new owner of a 1980 33'. Fairfax, VA > With loads of questions. Would love to hear from anyone. > > 1. I have a Redline Motor Generator in the front pass. side storage. > It appears to not be working. It has power cord that is plugged into it. > > After being repaired will the power cord power any of the outlets? > > 2. In front of the pass. front seat is a red switch. It pulls 15 amps. > But I have no idea what it runs. Help? > > 3. The blowers for each of the heaters do not work. Front sofa, dining > area, and bedroom. These are the ones that run off engine heat. Any > idea where the fuse is for these? > > 4. I had no hot water in the shower. Found the balance valve stuck. > Can I work it with some WD40 a little and replace or should I just > replace the balance valve. > > 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." > But the Ice Maker is not plugged into it. > > 6. My gas gauge works great except when I switch to diesel. Then it > pegs to Empty like it is shorted. It is not the sending unit. Other > most likely causes? > > Now for my funny story. > > First I have never driven a BlueBird before this trip. > > I bought the Bird from an individual in Chicago. > Flew to Chicago and drove 750 miles to Fairfax, VA. > About 150 miles into the trip it was snowing and raining hard. > I decided to make a stop to get gas and rest. As I was waiting in line > to get gas the air horn would start to blow ever so lightly. I would > tap the horn button, turn of the engine, and bang on the dash. After a > few minutes it stopped blowing. I was so embarrassed I went to a > different gas station. Once again as I was waiting in line at a truck > stop to get gas, I could hear the air horn blowing again, sometimes > softly, other times full blow. > > Finally after several minutes it would stop. So I figured it was a > rain related short. > > About 650 miles in the trip my legs were getting cramped so I tried to > stretch them when I was surprised with a full blow from the air horn. > > That's when I found the Air Horn Valve on the floor. My short was in > my leg. > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > -- 1980 33' Newbie with Questions and a funny story. - Chet Geist - 07-05-2005 14:27 I'll try to answer a few of the questions since my Blue Bird is similar. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of vabroker1 Sent: Tuesday, July 05, 2005 8:58 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] 1980 33' Newbie with Questions and a funny story. I am a new owner of a 1980 33'. Fairfax, VA With loads of questions. Would love to hear from anyone. 1. I have a Redline Motor Generator in the front pass. side storage. It appears to not be working. It has power cord that is plugged into it. After being repaired will the power cord power any of the outlets? Yes, it should run the Ice Maker only. 2. In front of the pass. front seat is a red switch. It pulls 15 amps. But I have no idea what it runs. Help? This is your engine heater and warms the 3208 in cold or cool weather for easier starting. 3. The blowers for each of the heaters do not work. Front sofa, dining area, and bedroom. These are the ones that run off engine heat. Any idea where the fuse is for these? 4. I had no hot water in the shower. Found the balance valve stuck. Can I work it with some WD40 a little and replace or should I just replace the balance valve. If this is the Moen valve you can buy a replacement cartridge in most hardware stores. 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." But the Ice Maker is not plugged into it. This is the 110 volt from the Red Line generator. 6. My gas gauge works great except when I switch to diesel. Then it pegs to Empty like it is shorted. It is not the sending unit. Other most likely causes? Now for my funny story. First I have never driven a BlueBird before this trip. I bought the Bird from an individual in Chicago. Flew to Chicago and drove 750 miles to Fairfax, VA. About 150 miles into the trip it was snowing and raining hard. I decided to make a stop to get gas and rest. As I was waiting in line to get gas the air horn would start to blow ever so lightly. I would tap the horn button, turn of the engine, and bang on the dash. After a few minutes it stopped blowing. I was so embarrassed I went to a different gas station. Once again as I was waiting in line at a truck stop to get gas, I could hear the air horn blowing again, sometimes softly, other times full blow. Finally after several minutes it would stop. So I figured it was a rain related short. About 650 miles in the trip my legs were getting cramped so I tried to stretch them when I was surprised with a full blow from the air horn. That's when I found the Air Horn Valve on the floor. My short was in my leg. ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] 1980 33' Newbie with Questions and a funny story. - imgetnab2 - 07-05-2005 14:31 "VA": I can only answer a couple of these, but here goes: On my '83, the red switch in front of the passenger seat runs the block heater (keeps the water in the block warm in the winter). You should have a thermostat next to the side door for the engine heat. Make sure that's turned on. there are also switches that power the fans and speed next to the registers, that also need to be switched. I can't tell you where the fuse is... Hope this helps, if only a little. Glad to have you in the group! Ken Johnson '83 FC 33 Midland, MI --- In WanderlodgeForum@yahoogroups.com, "vabroker1" wrote: > I am a new owner of a 1980 33'. Fairfax, VA > With loads of questions. Would love to hear from anyone. > > 1. I have a Redline Motor Generator in the front pass. side storage. > It appears to not be working. It has power cord that is plugged into it. > > After being repaired will the power cord power any of the outlets? > > 2. In front of the pass. front seat is a red switch. It pulls 15 amps. > But I have no idea what it runs. Help? > > 3. The blowers for each of the heaters do not work. Front sofa, dining > area, and bedroom. These are the ones that run off engine heat. Any > idea where the fuse is for these? > > 4. I had no hot water in the shower. Found the balance valve stuck. > Can I work it with some WD40 a little and replace or should I just > replace the balance valve. > > 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." > But the Ice Maker is not plugged into it. > > 6. My gas gauge works great except when I switch to diesel. Then it > pegs to Empty like it is shorted. It is not the sending unit. Other > most likely causes? > > Now for my funny story. > > First I have never driven a BlueBird before this trip. > > I bought the Bird from an individual in Chicago. > Flew to Chicago and drove 750 miles to Fairfax, VA. > About 150 miles into the trip it was snowing and raining hard. > I decided to make a stop to get gas and rest. As I was waiting in line > to get gas the air horn would start to blow ever so lightly. I would > tap the horn button, turn of the engine, and bang on the dash. After a > few minutes it stopped blowing. I was so embarrassed I went to a > different gas station. Once again as I was waiting in line at a truck > stop to get gas, I could hear the air horn blowing again, sometimes > softly, other times full blow. > > Finally after several minutes it would stop. So I figured it was a > rain related short. > > About 650 miles in the trip my legs were getting cramped so I tried to > stretch them when I was surprised with a full blow from the air horn. > > That's when I found the Air Horn Valve on the floor. My short was in > my leg. 1980 33' Newbie with Questions and a funny story. - Jay Darst - 07-05-2005 15:13 I have a "Winter/Summer" switch overhead at the drivers seat, the switch must be in the WINTER position for the chassis heating fans to be functional. Also, the thermostat on the wall for chasis heat must be calling for heat. Thaz how that stuff werks on my Bird anyhow... Jay Darst 85PT40 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "vabroker1" wrote: > 3. The blowers for each of the heaters do not work. Front sofa, dining > area, and bedroom. These are the ones that run off engine heat. Any > idea where the fuse is for these? > 1980 33' Newbie with Questions and a funny story. - pattypape - 07-05-2005 15:24 I will try to answer a few of the questions, But your 80 is a little different than my 88 FC , Redline is before an inverter was used. It may be better to investigate replacing with a later model DC/AC inverter. The switch in the passenger area may be the engine block heater. The ice maker is plugged into an outlet that is powered by the Redline Generator or an inverter to make more ice and keep it cold when not using shore power or when driving on the road. The shower is like the shower in your home. Take it apart, clean it an lubricate with silicone grease. I do not think WD40 is good for the rubber seals. Hope this helps, Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > I can't help with the questions. But I have felt dumb before. I had the > same issue with the AIR HORN. You are not alone. > > Welcome to the Forum! > > Curt Sprenger `87PT38, Anaheim, Calif. > > > vabroker1 wrote: > > > I am a new owner of a 1980 33'. Fairfax, VA > > With loads of questions. Would love to hear from anyone. > > > > 1. I have a Redline Motor Generator in the front pass. side storage. > > It appears to not be working. It has power cord that is plugged into it. > > > > After being repaired will the power cord power any of the outlets? > > > > 2. In front of the pass. front seat is a red switch. It pulls 15 amps. > > But I have no idea what it runs. Help? > > > > 3. The blowers for each of the heaters do not work. Front sofa, dining > > area, and bedroom. These are the ones that run off engine heat. Any > > idea where the fuse is for these? > > > > 4. I had no hot water in the shower. Found the balance valve stuck. > > Can I work it with some WD40 a little and replace or should I just > > replace the balance valve. > > > > 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." > > But the Ice Maker is not plugged into it. > > > > 6. My gas gauge works great except when I switch to diesel. Then it > > pegs to Empty like it is shorted. It is not the sending unit. Other > > most likely causes? > > > > Now for my funny story. > > > > First I have never driven a BlueBird before this trip. > > > > I bought the Bird from an individual in Chicago. > > Flew to Chicago and drove 750 miles to Fairfax, VA. > > About 150 miles into the trip it was snowing and raining hard. > > I decided to make a stop to get gas and rest. As I was waiting in line > > to get gas the air horn would start to blow ever so lightly. I would > > tap the horn button, turn of the engine, and bang on the dash. After a > > few minutes it stopped blowing. I was so embarrassed I went to a > > different gas station. Once again as I was waiting in line at a truck > > stop to get gas, I could hear the air horn blowing again, sometimes > > softly, other times full blow. > > > > Finally after several minutes it would stop. So I figured it was a > > rain related short. > > > > About 650 miles in the trip my legs were getting cramped so I tried to > > stretch them when I was surprised with a full blow from the air horn. > > > > That's when I found the Air Horn Valve on the floor. My short was in > > my leg. > > > > > > > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > > > -- 1980 33' Newbie with Questions and a funny story. - racin41@... - 07-05-2005 20:43 The engine heaters in our WL work as Jay Darst descibed. In addition, we have to have the ignition in the "on" or acessory position to operate or test the blowers. Bill & Rita in Roanoke, VA 1987 FC-35 [Non-text portions of this message have been removed] 1980 33' Newbie with Questions and a funny story. - vabroker1 - 07-07-2005 14:41 Thanks for your help. One last question. Red switch at rear bed bunk. --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > I'll try to answer a few of the questions since my Blue Bird is similar. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of vabroker1 > Sent: Tuesday, July 05, 2005 8:58 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 1980 33' Newbie with Questions and a funny > story. > > > I am a new owner of a 1980 33'. Fairfax, VA > With loads of questions. Would love to hear from anyone. > > 1. I have a Redline Motor Generator in the front pass. side storage. > It appears to not be working. It has power cord that is plugged into it. > > After being repaired will the power cord power any of the outlets? > > Yes, it should run the Ice Maker only. > > 2. In front of the pass. front seat is a red switch. It pulls 15 amps. > But I have no idea what it runs. Help? > > This is your engine heater and warms the 3208 in cold or cool weather for > easier starting. > > 3. The blowers for each of the heaters do not work. Front sofa, dining > area, and bedroom. These are the ones that run off engine heat. Any > idea where the fuse is for these? > > 4. I had no hot water in the shower. Found the balance valve stuck. > Can I work it with some WD40 a little and replace or should I just > replace the balance valve. > > If this is the Moen valve you can buy a replacement cartridge in most > hardware stores. > > > 5. I have an outlet under the kitchen sink labeled "Ice Maker Only." > But the Ice Maker is not plugged into it. > > This is the 110 volt from the Red Line generator. > > 6. My gas gauge works great except when I switch to diesel. Then it > pegs to Empty like it is shorted. It is not the sending unit. Other > most likely causes? > > Now for my funny story. > > First I have never driven a BlueBird before this trip. > > I bought the Bird from an individual in Chicago. > Flew to Chicago and drove 750 miles to Fairfax, VA. > About 150 miles into the trip it was snowing and raining hard. > I decided to make a stop to get gas and rest. As I was waiting in line > to get gas the air horn would start to blow ever so lightly. I would > tap the horn button, turn of the engine, and bang on the dash. After a > few minutes it stopped blowing. I was so embarrassed I went to a > different gas station. Once again as I was waiting in line at a truck > stop to get gas, I could hear the air horn blowing again, sometimes > softly, other times full blow. > > Finally after several minutes it would stop. So I figured it was a > rain related short. > > About 650 miles in the trip my legs were getting cramped so I tried to > stretch them when I was surprised with a full blow from the air horn. > > That's when I found the Air Horn Valve on the floor. My short was in > my leg. > > > > > > > > > -------------------------------------------------------------------- -------- > -- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > -------------------------------------------------------------------- -------- > -- > > > > [Non-text portions of this message have been removed] 1980 33' Newbie with Questions and a funny story. - pattypape - 07-07-2005 14:43 Electric hot water heater. Bill -- In WanderlodgeForum@yahoogroups.com, "vabroker1" wrote: > Thanks for your help. One last question. > Red switch at rear bed bunk. > > > --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" > wrote: > > I'll try to answer a few of the questions since my Blue Bird is > similar. > > > > Chet Geist > > 1981 FC33, Austin, Texas > > -----Original Message----- > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of vabroker1 > > Sent: Tuesday, July 05, 2005 8:58 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] 1980 33' Newbie with Questions and a > funny > > story. > > > > > > I am a new owner of a 1980 33'. Fairfax, VA > > With loads of questions. Would love to hear from anyone. > > > > 1. I have a Redline Motor Generator in the front pass. side > storage. > > It appears to not be working. It has power cord that is plugged > into it. > > > > After being repaired will the power cord power any of the outlets? > > > > Yes, it should run the Ice Maker only. > > > > 2. In front of the pass. front seat is a red switch. It pulls 15 > amps. > > But I have no idea what it runs. Help? > > > > This is your engine heater and warms the 3208 in cold or cool > weather for > > easier starting. > > > > 3. The blowers for each of the heaters do not work. Front sofa, > dining > > area, and bedroom. These are the ones that run off engine heat. > Any > > idea where the fuse is for these? > > > > 4. I had no hot water in the shower. Found the balance valve > stuck. > > Can I work it with some WD40 a little and replace or should I just > > replace the balance valve. > > > > If this is the Moen valve you can buy a replacement cartridge in > most > > hardware stores. > > > > > > 5. I have an outlet under the kitchen sink labeled "Ice Maker > Only." > > But the Ice Maker is not plugged into it. > > > > This is the 110 volt from the Red Line generator. > > > > 6. My gas gauge works great except when I switch to diesel. Then > it > > pegs to Empty like it is shorted. It is not the sending unit. > Other > > most likely causes? > > > > Now for my funny story. > > > > First I have never driven a BlueBird before this trip. > > > > I bought the Bird from an individual in Chicago. > > Flew to Chicago and drove 750 miles to Fairfax, VA. > > About 150 miles into the trip it was snowing and raining hard. > > I decided to make a stop to get gas and rest. As I was waiting > in line > > to get gas the air horn would start to blow ever so lightly. I > would > > tap the horn button, turn of the engine, and bang on the dash. > After a > > few minutes it stopped blowing. I was so embarrassed I went to a > > different gas station. Once again as I was waiting in line at a > truck > > stop to get gas, I could hear the air horn blowing again, > sometimes > > softly, other times full blow. > > > > Finally after several minutes it would stop. So I figured it was > a > > rain related short. > > > > About 650 miles in the trip my legs were getting cramped so I > tried to > > stretch them when I was surprised with a full blow from the air > horn. > > > > That's when I found the Air Horn Valve on the floor. My short > was in > > my leg. > > > > > > > > > > > > > > > > > > ----------------------------------------------------------------- --- > -------- > > -- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service. > > > > > > ----------------------------------------------------------------- --- > -------- > > -- > > > > > > > > [Non-text portions of this message have been removed] |
