The coolest motorhome you can buy - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Sandbox (/forumdisplay.php?fid=6) +--- Forum: Over-the-Top RV's, Buses, Trucks, and Cars (/forumdisplay.php?fid=66) +--- Thread: The coolest motorhome you can buy (/showthread.php?tid=9882) |
The coolest motorhome you can buy - davidbrady - 07-02-2013 23:25 Ebay item number: 200939081340 RE: The coolest motorhome you can buy - Arcticdude - 07-02-2013 23:45 That would make an NA FC look like a real hotrod! RE: The coolest motorhome you can buy - davidbrady - 07-03-2013 08:03 At least the engine is in the right place. :-) RE: The coolest motorhome you can buy - patticake - 07-03-2013 09:20 That is one neat bus, just needs a "little" interior work ![]() RE: The coolest motorhome you can buy - Arcticdude - 07-03-2013 14:37 At 22', that would be a cool toad. I wonder how it pulls at 85? RE: The coolest motorhome you can buy - patticake - 07-03-2013 21:52 I think it would pull fine, just needs an upgrade on the non turbo and hi-performance tires. Maybe a larger air intake and a straight exhaust will help even more ![]() Maybe David can do a coefficient on the drag for the streamlining ![]() |
