water pump motor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: water pump motor (/showthread.php?tid=992) |
water pump motor - Rose Mary - 09-01-2005 16:48 thank you Tom W for walking me thru checking power to the water pump. There is power so the motor must be fried. I may have left it on...don't know. It looks as if my brother may have replaced the motor before as the wiring to the pump/motor has had some changes or perhaps there was a bad wire. Question now is where I might find a small motor that would work. I think the pump is fine as I can turn the belt and it moves the pump gizmo...has anyone replaced just the little motor? thanks Rose Mary 82 FC 33 Oregon water pump motor - Ralph L. Fullenwider - 09-02-2005 00:39 Rosemary: I have 4 of the original pumps on hand. Will sell then at $105.00 plus shipping or I can remove a motor for you for $65.00 plus shipping. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:48 AM 9/2/2005 +0000, you wrote: >thank you Tom W for walking me thru checking power to the water pump. >There is power so the motor must be fried. I may have left it >on...don't know. > It looks as if my brother may have replaced the motor before as the >wiring to the pump/motor has had some changes or perhaps there was a >bad wire. >Question now is where I might find a small motor that would work. I >think the pump is fine as I can turn the belt and it moves the pump >gizmo...has anyone replaced just the little motor? >thanks >Rose Mary >82 FC 33 >Oregon > > > |
