S60 Engine Drive Belts - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Chassis (/forumdisplay.php?fid=23) +--- Thread: S60 Engine Drive Belts (/showthread.php?tid=9971) |
S60 Engine Drive Belts - cmillsap - 08-27-2013 17:49 I'm unable to find the part #s on my engine drive belts as they are worn off. I need a spare set. Does anyone have any available part #s for the S60 serpentine belt and the (paired) two a/c compressor belts? Otherwise, I will have to take them off and have them matched at NAPA. Chuck RE: S60 Engine Drive Belts - davidbrady - 08-27-2013 22:02 Hi Chuck, The serpentine belt is a NAPA 25-120720. I don't have a part number for the ac compressor belts; all I can add is to try to get a Gates matched pair. RE: S60 Engine Drive Belts - pgchin - 08-28-2013 08:47 (08-27-2013 22:02)davidbrady Wrote: Hi Chuck, Chuck, The Detroit Diesel part # for the Serpentine belt is 23521337 (for completeness in case other members use DD instead of NAPA) The 2 AC belts part number for Gates is GT17672 RE: S60 Engine Drive Belts - cmillsap - 08-28-2013 15:00 Here's a list of belt and filter part #s that I have compiled from several sources for an LXI. It may be useful to others when trying to find a replacement for their bus. LXI Filters & Belts Part #s LXi Air Filter Part #s ECOLITE 546895 WIX ECO-SM 46895 Baldwin # PA2723 Donaldson # P537449 Fleetgard # AH8505 Hastings # AF2269 Farr # 62891-3 ---------------------------------------------------------------------- LXi Oil & Fuel Filters Part #s Detroit Diesel S60 500 HP- ECU DD111 Oil capacity = 39 Quarts Multi-Grade 15-40 Oil Filter #1 = FG: LF3620 or equivalent Oil Filter #2 = FG: LF3620 or equivalent Fuel Filter #3 = FG: FF5206 or equivalent Fuel Filter #4 = FG: FS20203 or equivalent Coolant Filter = Specific for Coolant Type =Use DDF60 with Power Cool Plus Coolant ---------------------------------------------------------------------- LXi -DD S60 Serpentine Belt Part #s Outside Circumference (in) : 72.632" Top Width (in) : 1.647" Part Number: NBH 25120720 Product Line: NAPA Belts & Hoses DAYCO 5120720 Metric 12PK1830 Gates K120720 Napa 25-120720 Napa 25120720 Goodyear 4120720 Bando 12PK1828 VB Supply 720K12 K DD 23521337 ---------------------------------------------------------------------- LXi- DDS60 A/C Compressor Drive Belts Gates GT17672 Matched Pair (Discontinued) Gates 9710 Single Belt (2 Required) ---------------------------------------------------------------------- LXi Hydraulic Oil Reservoir Filter Part #s • BALDWIN PT8487 • DONALDSON P55-0698 • FRAM C7058 • NAPA 7196 • WIX 57196 ---------------------------------------------------------------------- Powertech 15KW Filters & Belt Part #s Fuel filter; • BB #3970860 • NAPA #3390 • Powertech #08FF081 • Kubota #70000-43081 Oil filter; • BB #3970878 • NAPA #1515 • Baldwin #B5 • Powertech #01FO091 • WIX #51068 • Kubota #70000-32091 Air filter; • BB #3838158 • Donaldson #ECB05-5001 • Powertech #04FA080 • Kubota #70000-11080 Fan Belt; • With Idler Pulley; • Powertech #03BF9447 $22.97 • Kubota #15469-97010 or #15469-73010 (not specified idler or[/u] alternator) • NAPA #XL 25-9447 Dimensions; 31/64"X44-7/8" (12.5/13mm X 1140mm) • With Alternator; • Powertech #03BF0203 ---------------------------------------------------------------------- LXi Allison 4060 Transmission Filter Part # Allison Kit # 29548988 RE: S60 Engine Drive Belts - cmillsap - 08-28-2013 23:19 (08-28-2013 08:47)pgchin Wrote:(08-27-2013 22:02)davidbrady Wrote: Hi Chuck, David, Pete, The Gates GT17672 Matched Set is no longer sold. The New replacement # is Gates 9710 which is a single belt. NOTE: I was told that the reason that matched sets are no longer necessary is because their belts are now all laser cut and will be spot on size with each other of the same sized belt. Chuck |
