450 LXi AC water drain leaks
03-17-2014, 21:10 (This post was last modified: 03-18-2014 11:28 by dentmac.)
More in the never ending battle. Pic looking up near AC unit.
Remove centre ceiling panals -add section of pex pipe with union. Using a Facet wrench (ground down to be thinner) makes it possible to tighten the nuts on the Tee Clean up the mold.
Fun -- Then got to do it again for each AC. all 4 leaking
03-18-2014, 08:17
RE: 450 LXi AC water drain leaks
Ross, don't feel bad. My rear air in the 97 did the same thing. It was a bear to get to. The worst thing: it leaked on the bed when I was sleeping.
03-18-2014, 10:55
You sure it was the AC? Or is that just what you're telling Brenda!!!
03-18-2014, 11:59
(03-18-2014 10:55)Arcticdude Wrote:  You sure it was the AC? Or is that just what you're telling Brenda!!!
Swooooooosh! Big GrinBig GrinBig Grin
03-18-2014, 19:43
That was the old hand in bowl trickRolleyes
