Looking for key lock or parts
11-22-2014, 14:19
(This post was last modified: 11-22-2014 15:12 by dentmac.)
Hi
The cast metal tab that turns to hold outside door closed is broken off. (Electronic area beside driver) Idea as to replacement. ...Duct tape is not impressive ! UPDATE: Found lots of them.. Just not the same one They are called "Metal Wafer Cam lock" Even Home Depot has them. < $5 ( no doubt made in China ) Ross MacKillop Wiarton Ontario 2006 450 Lxi |
11-25-2014, 00:41
RE: Looking for key lock or parts
Ross,
Often the keyed portion just pulls out of the barrel in case you haven't already found this. You could buy any of the locks, swap barrels and be good as new. John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
11-25-2014, 01:29
(11-25-2014 00:41)Arcticdude Wrote: Ross, Ross a good google search to do is search images. some interesting options come up. I like the idea of a combination lock for the electric shore cord compartment Gregory O'Connor 2001 LXi43ss Romoland California 92585 951-830-5997 Rainbowrv.com |
11-25-2014, 14:26
Hi,
Thanks everyone, I have a cheap Chinese version in there now but am watching for correct replacement or one that I can change the key cylinder. It is the same as the 450 fuel locks. FYI, the electric compartment is locked by the central electric locks but the battery compartment is not. Combination there would be nice. (11-25-2014 01:29)GregOConnor Wrote:(11-25-2014 00:41)Arcticdude Wrote: Ross, Ross MacKillop Wiarton Ontario 2006 450 Lxi |
