Generator woes
03-07-2007, 15:37
Generator woes
Gregory,
Thanks for the memory jog. You know, I believe the reason we had the last gen set replaced was due to the main shaft being snapped. Relying on a Kohler Dealer doing the first replacement job, I'm sure I relied on their expertise during installation and used new spec bearings, etc. However, you just never know..... Due to the age of the entire unit, I'm leaning more towards a new generator, and cross this repair off my list.... Thanks for all you help! Todd Desgranges '87 Stuart, FL Gregory OConnor Todd, A good local resource for repair on many engine driven items is a owner operated equipment rental yard. These folks develop a keen sence for; 'cause of failure','diagnostic for repair','inhouserepair ability or out-source contacts'. Factory rep repair facilities are too much into remove and replace. For the bearing to fail in such a short time, something was overlooked. Did they replace the old genhead four years ago without repairing the cause of the oldgenhead failure??? I wonder if the direct drive has a coupler???? Was the old coupler key used??? Is it key failure???? I wonder if the mounts on the genhead were changed ( with the new unit) but the mounts on the engine remained soft and the difference caused raidial stress on the bearing?????? Was the genhead torqued down to spec?? Did any of the install bolts bottom out??? I wonder if there is a key (alignment pin) in the bellhouse to the genhead that was not installed???? When replacing bearings, sometimes repairmen only go for size of fit and overlook environment. (bearings in a oilbath case are different than bearings engineered for a hot dry saddle). You should get MFG specs for the bearing and not trust the code on the failed bearing!!!! Look for a crack in the bearing saddle??? Starter failure is often due to low battery charge start ups. Low battery startup is a derived event if your genset uses the house bank to start. Most starters can be taken in to a specility shop and rebuilt for less than $200. Good luck with your repair. Remember to also repair "the cause of failure" GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > Hello Everyone! > > Long time since I've been here..... I'm having a problem again with my > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > week, misdiagnosed the problem and now I'm in a worse jam. The > bearing seazed and the main shaft that holds the Generator to the > Engine snapped. The Kohler repairman informed me that it was an > injector problem, installed a new starter and handed me a $2,200.00 > bill. After I finished pouting, which took about 2 months, I'm ready > to start looking for someone in the South Florida Area, preferably > Miami, to do the job. I know the Diesel Engine is in good shape, and I > had a new Generator portion installed about 4 years ago. We will be > heading back North in about a month and sure would like to have an > operational Generator prior to departure. Any help sure would be > appreciated. Thanks!!! > Todd Desgranges > 87Wanderlodge40 > Stuart, FL > --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. [Non-text portions of this message have been removed] |
03-07-2007, 15:39
Generator woes
RE,
I believe it's a John Deere..... Todd '87 Stuart, FL putneyflash@... wrote: Eric: If its a perkins engine a caterpillar daeler generator shop may be able to help. RE in Georgia > > From: "Eric Johnson" > Date: 2007/03/07 Wed AM 09:06:10 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Generator Woes > > Todd, > From your story, I'm pretty sure you've decided to stick with the original Kohler generator > since you've put quite a bit of effort and money into it. However, you may want to > consider replacing the whole unit with a new diesel generator from Powertech. You don't > have to shell out many $2,200 repair bills before you've bought a new generator. > Powertech's factory is located in Leesburg Florida. They're easy to work with. They let us > stay in our coach overnight at the plant while they did an install for us. > Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > > > Hello Everyone! > > > > Long time since I've been here..... I'm having a problem again with my > > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > > week, misdiagnosed the problem and now I'm in a worse jam. The > > bearing seazed and the main shaft that holds the Generator to the > > Engine snapped. The Kohler repairman informed me that it was an > > injector problem, installed a new starter and handed me a $2,200.00 > > bill. After I finished pouting, which took about 2 months, I'm ready > > to start looking for someone in the South Florida Area, preferably > > Miami, to do the job. I know the Diesel Engine is in good shape, and I > > had a new Generator portion installed about 4 years ago. We will be > > heading back North in about a month and sure would like to have an > > operational Generator prior to departure. Any help sure would be > > appreciated. Thanks!!! > > Todd Desgranges > > 87Wanderlodge40 > > Stuart, FL > > > > > > --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. [Non-text portions of this message have been removed] |
03-08-2007, 01:11
Generator woes
Todd,
Our '87 has the Yanmar diesel engine driving the alternator. Your engine is probable a Yanmar. Yanmar makes engines and small tractors, and markets some of them through John Deere in the US. .Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Todd Desgranges wrote: > RE, > I believe it's a John Deere..... > Todd > '87 Stuart, FL > > putneyflash@... > Eric: If its a perkins engine a caterpillar daeler generator shop may > be able to help. > > RE in Georgia > > > > From: "Eric Johnson" > > Date: 2007/03/07 Wed AM 09:06:10 EST > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Re: Generator Woes > > > > Todd, > > From your story, I'm pretty sure you've decided to stick with the > original Kohler generator > > since you've put quite a bit of effort and money into it. However, > you may want to > > consider replacing the whole unit with a new diesel generator from > Powertech. You don't > > have to shell out many $2,200 repair bills before you've bought a > new generator. > > Powertech's factory is located in Leesburg Florida. They're easy to > work with. They let us > > stay in our coach overnight at the plant while they did an install > for us. > > Eric in San Antonio > > 84FC35SBWL2 > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > Hello Everyone! > > > > > > Long time since I've been here..... I'm having a problem again > with my > > > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > > > week, misdiagnosed the problem and now I'm in a worse jam. The > > > bearing seazed and the main shaft that holds the Generator to the > > > Engine snapped. The Kohler repairman informed me that it was an > > > injector problem, installed a new starter and handed me a $2,200.00 > > > bill. After I finished pouting, which took about 2 months, I'm ready > > > to start looking for someone in the South Florida Area, preferably > > > Miami, to do the job. I know the Diesel Engine is in good shape, > and I > > > had a new Generator portion installed about 4 years ago. We will be > > > heading back North in about a month and sure would like to have an > > > operational Generator prior to departure. Any help sure would be > > > appreciated. Thanks!!! > > > Todd Desgranges > > > 87Wanderlodge40 > > > Stuart, FL > > > > > > > > > > > > > --------------------------------- > Never miss an email again! > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. > > [Non-text portions of this message have been removed] > > |
03-08-2007, 02:55
Generator woes
Todd,
We bought the largest totally enclosed unit that would fit in our gen compartment which was the Powertech 8 KW. We wanted a totally enclosed unit for the sound reduction and it is much quieter than the original gen. The powerplant is a 3 cylinder Kubota diesel and it has been very reliable. We have over 1,000 trouble free hours on it. We chose Powertech on the recommendation of Blue Bird tech staff who said they were the generator supplier for new BB's. We have two roof a/c's and the unit has never bogged down with any electrical load we've put on it. If you want to run 3 a/c's, you probably need a higher capacity generator than the 8 KW. Our original and replacement generators both had the radiator mounted together with the unit as one package. The installed cost of the new generator in 2001 was $6323 with tax. Powertech labor to remove the old generator and install the new one was $800 and is included in the above price. Your coach generator compartment dimensions are probably different from our FC. If you want to explore this idea further, I suggest you contact Powertech directly at the factory. Their number is (352) 365-2777. Good luck with whatever you choose to do! Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, Todd Desgranges > > Hello Eric, > I've been thinking about the new replacement because we depend on the unit so much. Did you install a new 12.5K or a different size? What did your new generator and installation cost? Also, did you keep the remote radiator, or get an all inclusive generator in its own case? If I'm going to be keeping this Coach for awhile, that might be my best bet. Thanks for all your help! > > Todd Desgranges > > > Eric Johnson > Todd, > From your story, I'm pretty sure you've decided to stick with the original Kohler generator > since you've put quite a bit of effort and money into it. However, you may want to > consider replacing the whole unit with a new diesel generator from Powertech. You don't > have to shell out many $2,200 repair bills before you've bought a new generator. > Powertech's factory is located in Leesburg Florida. They're easy to work with. They let us > stay in our coach overnight at the plant while they did an install for us. > Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > > > Hello Everyone! > > > > Long time since I've been here..... I'm having a problem again with my > > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > > week, misdiagnosed the problem and now I'm in a worse jam. The > > bearing seazed and the main shaft that holds the Generator to the > > Engine snapped. The Kohler repairman informed me that it was an > > injector problem, installed a new starter and handed me a $2,200.00 > > bill. After I finished pouting, which took about 2 months, I'm ready > > to start looking for someone in the South Florida Area, preferably > > Miami, to do the job. I know the Diesel Engine is in good shape, and I > > had a new Generator portion installed about 4 years ago. We will be > > heading back North in about a month and sure would like to have an > > operational Generator prior to departure. Any help sure would be > > appreciated. Thanks!!! > > Todd Desgranges > > 87Wanderlodge40 > > Stuart, FL > > > > > > > > > --------------------------------- > Don't pick lemons. > See all the new 2007 cars at Yahoo! Autos. > > [Non-text portions of this message have been removed] > |
03-08-2007, 03:49
Generator woes
Hi Todd About five years ago I replace my old worn out Kohler generator with a 12kw powertech 4 cyllinder kubota.Have not had any trouble with the new unit.I did keep the remote radiator and and fan. Bob Loomas 1985 PT 36 > > RE, > I believe it's a John Deere..... > Todd > '87 Stuart, FL > > putneyflash@... wrote: > Eric: If its a perkins engine a caterpillar daeler generator shop may be able to help. > > RE in Georgia > > > > From: "Eric Johnson" > > Date: 2007/03/07 Wed AM 09:06:10 EST > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Generator Woes > > > > Todd, > > From your story, I'm pretty sure you've decided to stick with the original Kohler generator > > since you've put quite a bit of effort and money into it. However, you may want to > > consider replacing the whole unit with a new diesel generator from Powertech. You don't > > have to shell out many $2,200 repair bills before you've bought a new generator. > > Powertech's factory is located in Leesburg Florida. They're easy to work with. They let us > > stay in our coach overnight at the plant while they did an install for us. > > Eric in San Antonio > > 84FC35SBWL2 > > > > --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > > > > > Hello Everyone! > > > > > > Long time since I've been here..... I'm having a problem again with my > > > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > > > week, misdiagnosed the problem and now I'm in a worse jam. The > > > bearing seazed and the main shaft that holds the Generator to the > > > Engine snapped. The Kohler repairman informed me that it was an > > > injector problem, installed a new starter and handed me a $2,200.00 > > > bill. After I finished pouting, which took about 2 months, I'm ready > > > to start looking for someone in the South Florida Area, preferably > > > Miami, to do the job. I know the Diesel Engine is in good shape, and I > > > had a new Generator portion installed about 4 years ago. We will be > > > heading back North in about a month and sure would like to have an > > > operational Generator prior to departure. Any help sure would be > > > appreciated. Thanks!!! > > > Todd Desgranges > > > 87Wanderlodge40 > > > Stuart, FL > > > > > > > > > > > > > > > > > > --------------------------------- > Never miss an email again! > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. > > [Non-text portions of this message have been removed] > |
03-08-2007, 05:22
Generator woes
Todd, if you reengineere the bus with a new genset be sure to realize
heat and airflow. Some of the box gensets are self insulated and require flow past heat sinks. If you stuff a box in your box, you may generate too much heat. I have no basis for this assumption but I wonder if the Onan RV Box sets are built to hold up to long duty use like the Big powertecs????? I wonder if the boxset powertecs are built to compete with the Onan RV market sets????? I have some portable light towers for construction sites that have over 10,000 hours and run very well. The gen heads and engines are much like the setup in the birds except for the mufflers , noise insulation and load. The towers are loaded to the max most of the time and I understand that it is better for the genset to be loaded up when it runs. I have several Homedepot gensets that run well but I do not think they will last more then the intended 100 hours per the year. If you make a change, this forum may be a good place to get a feel for salvage value of your old gen set. I would say the broken unit should be worth $2,500?????( however I am not in the market) Other forum members may shed light on salvage value Some time it is not a fact of 'throwing good money after bad'. Its who you have on mound. I hope you find a good tech to help with your repair or replacement. GregoryO'Connor 94ptRomolanCa --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > Todd, > We bought the largest totally enclosed unit that would fit in our gen compartment which > was the Powertech 8 KW. We wanted a totally enclosed unit for the sound reduction and it > is much quieter than the original gen. The powerplant is a 3 cylinder Kubota diesel and it > has been very reliable. We have over 1,000 trouble free hours on it. We chose Powertech > on the recommendation of Blue Bird tech staff who said they were the generator supplier > for new BB's. > > We have two roof a/c's and the unit has never bogged down with any electrical load we've > put on it. If you want to run 3 a/c's, you probably need a higher capacity generator than > the 8 KW. > > Our original and replacement generators both had the radiator mounted together with the > unit as one package. The installed cost of the new generator in 2001 was $6323 with tax. > Powertech labor to remove the old generator and install the new one was $800 and is > included in the above price. > > Your coach generator compartment dimensions are probably different from our FC. If you > want to explore this idea further, I suggest you contact Powertech directly at the factory. > Their number is (352) 365-2777. > > Good luck with whatever you choose to do! > > Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com, Todd Desgranges > > > > Hello Eric, > > I've been thinking about the new replacement because we depend on the unit so much. > Did you install a new 12.5K or a different size? What did your new generator and > installation cost? Also, did you keep the remote radiator, or get an all inclusive generator > in its own case? If I'm going to be keeping this Coach for awhile, that might be my best > bet. Thanks for all your help! > > > > Todd Desgranges > > > > > > Eric Johnson > > Todd, > > From your story, I'm pretty sure you've decided to stick with the original Kohler > generator > > since you've put quite a bit of effort and money into it. However, you may want to > > consider replacing the whole unit with a new diesel generator from Powertech. You don't > > have to shell out many $2,200 repair bills before you've bought a new generator. > > Powertech's factory is located in Leesburg Florida. They're easy to work with. They let us > > stay in our coach overnight at the plant while they did an install for us. > > Eric in San Antonio > > 84FC35SBWL2 > > > > --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > > > > > Hello Everyone! > > > > > > Long time since I've been here..... I'm having a problem again with my > > > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > > > week, misdiagnosed the problem and now I'm in a worse jam. The > > > bearing seazed and the main shaft that holds the Generator to the > > > Engine snapped. The Kohler repairman informed me that it was an > > > injector problem, installed a new starter and handed me a $2,200.00 > > > bill. After I finished pouting, which took about 2 months, I'm ready > > > to start looking for someone in the South Florida Area, preferably > > > Miami, to do the job. I know the Diesel Engine is in good shape, and I > > > had a new Generator portion installed about 4 years ago. We will be > > > heading back North in about a month and sure would like to have an > > > operational Generator prior to departure. Any help sure would be > > > appreciated. Thanks!!! > > > Todd Desgranges > > > 87Wanderlodge40 > > > Stuart, FL > > > > > > > > > > > > > > > > > --------------------------------- > > Don't pick lemons. > > See all the new 2007 cars at Yahoo! Autos. > > > > [Non-text portions of this message have been removed] > > > |
03-09-2007, 02:23
Generator woes
Todd, sorry about comming in late to the discussion. I also HAD
Kohler/Perkins problems and the Kohler folks just wanted to "buy and throw parts at the problem" After about 3K I said uncle and decided to go new. I too have a new PowerTech 12kw genset and could not be happier. It was put in our 86FC the install was "creative" to say the least but none the less it is great. Reliable, QUIET, and new technology. You will not go wrong with a PowerTech. They are quality guys. BUT I have my 12.5kw Kohler/Perkins complete unit still and for sale. It has about 1800 hrs on it, tons of new part on the Kohler, and the Perkins runs like a sewing machine, and does not leak a drop of oil. If interested contact me offline cme4boat(at)aol(dot) com. Scott B 86FC35 Murrells Inlet SC "right next to the rally" and "was tired of genset problems" --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > Hello Everyone! > > Long time since I've been here..... I'm having a problem again with my > Generator on the '87 Wanderlodge.... I had Kohler work on it for a > week, misdiagnosed the problem and now I'm in a worse jam. The > bearing seazed and the main shaft that holds the Generator to the > Engine snapped. The Kohler repairman informed me that it was an > injector problem, installed a new starter and handed me a $2,200.00 > bill. After I finished pouting, which took about 2 months, I'm ready > to start looking for someone in the South Florida Area, preferably > Miami, to do the job. I know the Diesel Engine is in good shape, and I > had a new Generator portion installed about 4 years ago. We will be > heading back North in about a month and sure would like to have an > operational Generator prior to departure. Any help sure would be > appreciated. Thanks!!! > Todd Desgranges > 87Wanderlodge40 > Stuart, FL > |
03-09-2007, 02:30
Generator woes
Hey Bob, that is what I have. About 1 1/2 yrs old and almost 500
trouble free hours. Could not be happier. We replaced the electric fan and rad with one that lays on the genset tray and blows down (keeps the heat away from sitting under the awning, and much quieter) The fan looks like the one on the hvac unit at the house. Covered the louvers with a sheet of black painted galv metal to keep the original looks. My genset was installed horizontally, (front to back of bus) with less than 3/4 of an inch clearance on the sides. Great for maintenance, can change the oil with simply sliding out the genset. Scott B 86FC SC --- In WanderlodgeForum@yahoogroups.com, "robertnloomas" > > --- In WanderlodgeForum@yahoogroups.com, Todd Desgranges > > > Hi Todd About five years ago I replace my old worn out Kohler > generator with a 12kw powertech 4 cyllinder kubota.Have not had any > trouble with the new unit.I did keep the remote radiator and and fan. > Bob Loomas 1985 PT 36 > > > > RE, > > I believe it's a John Deere..... > > Todd > > '87 Stuart, FL > > > > putneyflash@ wrote: > > Eric: If its a perkins engine a caterpillar daeler > generator shop may be able to help. > > > > RE in Georgia > > > > > > From: "Eric Johnson" > > > Date: 2007/03/07 Wed AM 09:06:10 EST > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Re: Generator Woes > > > > > > Todd, > > > From your story, I'm pretty sure you've decided to stick with > the original Kohler generator > > > since you've put quite a bit of effort and money into it. > However, you may want to > > > consider replacing the whole unit with a new diesel generator > from Powertech. You don't > > > have to shell out many $2,200 repair bills before you've bought > a new generator. > > > Powertech's factory is located in Leesburg Florida. They're easy > to work with. They let us > > > stay in our coach overnight at the plant while they did an > install for us. > > > Eric in San Antonio > > > 84FC35SBWL2 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "tdesgranges" > > > > > > > > > Hello Everyone! > > > > > > > > Long time since I've been here..... I'm having a problem again > with my > > > > Generator on the '87 Wanderlodge.... I had Kohler work on it > for a > > > > week, misdiagnosed the problem and now I'm in a worse jam. The > > > > bearing seazed and the main shaft that holds the Generator to > the > > > > Engine snapped. The Kohler repairman informed me that it was > an > > > > injector problem, installed a new starter and handed me a > $2,200.00 > > > > bill. After I finished pouting, which took about 2 months, I'm > ready > > > > to start looking for someone in the South Florida Area, > preferably > > > > Miami, to do the job. I know the Diesel Engine is in good > shape, and I > > > > had a new Generator portion installed about 4 years ago. We > will be > > > > heading back North in about a month and sure would like to > have an > > > > operational Generator prior to departure. Any help sure would > be > > > > appreciated. Thanks!!! > > > > Todd Desgranges > > > > 87Wanderlodge40 > > > > Stuart, FL > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > Never miss an email again! > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > out. > > > > [Non-text portions of this message have been removed] > > > |
