M380 front blow out
09-13-2018, 14:38
M380 front blow out
The m380 and m450 have basically the same front end.
If you have a front tire blow out at 60 mph on an m380, can you control it or does it do like the m450? If you can not control it, are there any products that will allow you to control the coach? Richard Ramsey |
09-13-2018, 15:26
RE: M380 front blow out
Richard,
Some in the Class A world and in the Prevost bus world run Tyron tire inserts: http://www.tyron-usa.com/ They have 2 designs, one is a set of bands designed to keep the tire bead seated on the outside of the wheel and the other is a round donut that clamps to the inside of the wheel to allow runflat operation. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
09-13-2018, 15:31
(This post was last modified: 09-13-2018 15:49 by dentmac.)
Hutchinson Composite Runflat.. "CRF".. Buffalo (or the Tyron ATR .. not the tyron band)
here: https://www.hutchinsoninc.com/security/runflats/ Ross Ross MacKillop Wiarton Ontario 2006 450 Lxi |
