Voltage Readings
12-23-2005, 02:48
Voltage Readings
I don't know a lot about electricity, so I need some help here:
What should the voltage reading on the engine volt gauge be while
driving? I have always thought that when driving normally, the volt
gauge should read somewhere around 14.5 when the alternator is
putting out properly. Last night, when driving home from a repair
shop where several items were replaced (including 4 new batteries),
the gauge was only reading a bit above 12 when driving. Should I be
concerned about my alternator?
Also...what is the purpose of the 'Amps' gauges? What do they
demonstrate? My 82 FC has one on the dash and also one at the power
switch in the step well. Neither gauge ever seems to move much if at
all. What should these two gauges be showing me?
Thanks
Scott Forman
82 FC35RB
Memphis
12-23-2005, 04:07
Voltage Readings
Dash Voltage - My experience is the dash volt gauge should read about
13.5 volts. Gauges get old and the calibration may be off, so with the
engine running, use a meter and take a volt reading at the alternator .
12.5+ is good, especially with the new batteries. Also take an AMP
reading at the alternator. If there are positive AMPs the alternator
should be good. AMPs will vary depending on the alternator load.
AMP Gauges - I'm not sure about the '82FC. The one in the step-well is
probable tied in with the generator and shore power. The dash gauge is
probable the engine alternator AMP output. With the generator running,
or hooked to shore power, and the power source set to GEN or SHORE,
check the step-well gauge with no load, then again with a couple AC
units running. No load = low reading...two AC units on = higher reading
of maybe 20 or 30 AMPs. Check the dash AMP gauge while conducting this
test.
Jeff Miller or others will add clarity to this I'm sure.
Hope this helps.
> Thanks
> Scott Forman
> 82 FC35RB
> Memphis
> SPONSORED LINKS
> Recreational vehicles
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
> Automotive maintenance
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
> Recreational vehicle dealer
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
> Used recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
> Automotive radiators
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
12-23-2005, 04:33
Voltage Readings
Hi Scott,
> help here:
Let's first chat a moment about 12V batteries. To
charge at all, they must be presented with 14.1 volts
or more, and a fully charged, good, 12v battery, "at
rest" (i.e. without a load, and roughly an hour or
more after charging has ceased) should indicate 12.65v
while a "discharged" battery under the same
circumstances will show 12v or less. Note that if the
battery is not "at rest," measuring its voltage will
not present an accurate picture, and it really needs
to be checked with a "Load testing" device for true
accuracy.
It is common to hear an inverter/charger "float
charges" at 13.4 or 13.1 or so; however, "float
charging" is generally understood not to mean "adding
any charge," but to be an "in-between state" where the
charger system has determined charging (14v+) is no
longer needed, but monitoring is necessary in the
event charging becomes necessary.
> gauge be while
> driving?
Engine alternator charging is controlled by a
regulator system which adjusts both voltage (still
must be above 14v to charge) and amperage, which is
"current flow." The two readings are positively
correlated, though not necessarily, directly, in a one
to one relationship.
Voltage and Amperage can be read from the dash
gauges; however, the gauges are generally reading
totals and not simply the portion which is "battery
charging." Therefore, depending upon the regulator
settings and total system demands for current/power,
the regulator may provide voltages from 12 through 18,
and amperages from virtually nil to the maximum output
of the alternator. For most Birds, we'd not find it
unusual to see around 14 1\2 volts and 20-30 amps.
Significantly higher or lower of either, would be
cause to ask "why," but not necessarily become
alarmed.
> normally, the volt
> alternator is
> from a repair
> new batteries),
With the engine running, turn on all headlights
and 12V circuits and see what you find, especially the
amperage.
No change, and assuming the gauges are reasonably
correct, I might be questioning the regulator. If it
is found normal, then the alternator.
> What do they
> one at the power
Generally, the one(s) at the step well are measuring
the amperage of the 110V circuit(s). When connected
to shore power, turn on an air conditioner compressor
and watch the amperage gauge.
> to move much if at
Hopefully, some of the above may have answered this
for you, Scott.
> Thanks
> Scott Forman
> 82 FC35RB
> Memphis
John Suter
__________________________________________
Yahoo! DSL – Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
12-23-2005, 08:57
Voltage Readings
John,
Thanks for the wealth of information. I tested with a multi-meter
today, and it looks like everything is fine...I guess maybe the
voltage gauge is just tired.
Scott
--- In WanderlodgeForum@yahoogroups.com, John Suter
> Hi Scott,
> > help here:
> accuracy.
> > gauge be while
> > driving?
> alarmed.
> > normally, the volt
> > alternator is
> > from a repair
> > new batteries),
> amperage.
> > What do they
> > one at the power
> > to move much if at
> for you, Scott.
> > Thanks
> > Scott Forman
> > 82 FC35RB
> > Memphis
> John Suter
> dsl.yahoo.com
12-23-2005, 09:46
Voltage Readings
> John,
> a multi-meter
> guess maybe the
> Scott
Great! Happy to hear of problems that turn out
relatively minor.
Generally speaking, if a direct current (DC) voltage
gauge displays, but occasionally or consistently
appears "lazy," one likely culpit is a "poorly"
grounded meter. As a DC dash meter often shares its
"ground connection" with other nearby 12v devices, and
all are located a good "electrical" distance from the
negative battery ground post(s), be on the lookout for
similar "lazy" behavior from other 12v devices,
lights, fans, etc., especially when they are
collectively "on" and draw significant
amperage/current. Satellite dishes, and other circuit
boards fed with 12v, are particularly sensitive to
aging and poor ground connections and can be damaged.
When you "get your fill" of the poor/lazy behavior,
consider adding an additional ground wire.
John Suter
> > Hi Scott,
> some
> > > help here:
> To
> volts
> "at
> 12.65v
> the
> will
> needs
> true
> > accuracy.
> "adding
> the
> no
> volt
> > > gauge be while
> > > driving?
> is
> one
> "battery
> regulator
> current/power,
> 18,
> output
> it
> > alarmed.
> > > normally, the volt
> > > alternator is
> home
> > > from a repair
> (including 4
> > > new batteries),
> headlights
> the
> > amperage.
> reasonably
> it
> > > What do they
> also
> > > one at the power
> measuring
> connected
> compressor
> > > to move much if at
> me?
> this
> > for you, Scott.
> > > Thanks
> > > Scott Forman
> > > 82 FC35RB
> > > Memphis
> > John Suter
> > dsl.yahoo.com
Yahoo! for Good - Make a difference this year.
http://brand.yahoo.com/cybergivingweek2005/
12-23-2005, 13:42
Voltage Readings
Some good information, hope you don't mind me adding my 2-cents:
The ammeter in the stepwell of the '82 ('70s through '83) is for the
12v output of the chargers to the main batteries. Usually this reads
nothing, but should read a significant output when charging low-
batteries from shore/APU power.
The ammeter in the dash of the '82 (through '83) is the charging amps
(left is discharge, right is charge) of the main battery bank from
the alternator/coach loads. You should never see it to the left with
the engine running, often around 20-30a to the right (charge) side
and rarely above that (only if batteries are significantly discharged
and there are few coach loads on).
New batteries have a greater capacity to accept a charge than do old
batteries, so you might see higher charging amps and slightly lower
voltage until they are fully charged for the first time (if not
completely charged when they were installed).
The voltmeter on the dash is the main battery voltage. As others have
mentioned, should be around 14v when the engine is running. With
everything off, this is possible, but as John mentioned the gauge is
subject to other draws in the dash etc. and drops significantly when
other loads on the dash are turned on (especially '84-'86). The
voltmeter would benefit a good deal from "home-runs", wire run
directly to the battery bank to read battery voltage and display
accurate information.
Some of the alternators need a little bump in RPM to excite the
alternator when first started, then it'll charge at idle.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
volt
be
power
at
> Thanks
> Scott Forman
> 82 FC35RB
> Memphis
12-23-2005, 19:33
Voltage Readings
Jeff- I don't have an ammeter in the dash on my 83 PT40. I do have one in
the rear closet by the engine preheat/ water heater switches. Kinda hard to read
that gauge while driving~ Ernie
