Inverter installation help
01-18-2006, 16:53
I picked up a 1500 watt inverter and need some help installing it. My
coach does not appear to have ever had an inverter but I'm not sure, there are no wires in the front left bay and most I've seen had a rediline in this location. So my question is are the Wanderlodges prewired for an inverter? If so where do I look for the connection point? Troy Tikalsky Waconia, MN 1983 FC33 |
01-20-2006, 02:01
My 1981 FC-33 was pre-wired for a Redi-line, there is a junction box
for it in the rear upper corner of the front right bay. There should be junction boxes in the upper storage cabinets on the curbside of the coach behind the woodgrain panels labelled redi-line. There should be another one located under the sink where my redi-line relay was located. I ended up putting my inverter/charger in place of the original battery chargers and connecting them with 16' of 2/0 cable(s) to the batteries in the left front battery bay. My right front bay has 2-8D starting batteries. I have more details on my inverter installation in the files section of the FC_Wanderlodge Yahoo!Group. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > > I picked up a 1500 watt inverter and need some help installing it. My > coach does not appear to have ever had an inverter but I'm not sure, > there are no wires in the front left bay and most I've seen had a > rediline in this location. So my question is are the Wanderlodges > prewired for an inverter? If so where do I look for the connection point? > > Troy Tikalsky > Waconia, MN > 1983 FC33 > |
01-20-2006, 07:27
No such thing as a dumb questions....
A Redi-Line was (is) a electric 12v motor device, that turns a AC generator, that generates 110v ac. It was designed to supply 110v power to the electric drapes, ice maker, and maybe a few other low amp 110v devices, in lieu of starting the genset or in the case of not having an inverter (or shore power available). No too efficient, but a neat device for it's time. Kevin McKeown Yorba Linda, CA 1986 38' PT (without a Redi-Line) [Non-text portions of this message have been removed] |
01-20-2006, 09:43
OK...dumb question here...what is a Redi-Line? Does/did my 82 FC35
have one? Thanks Scott --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > My 1981 FC-33 was pre-wired for a Redi-line, there is a junction box > for it in the rear upper corner of the front right bay. There should > be junction boxes in the upper storage cabinets on the curbside of the > coach behind the woodgrain panels labelled redi-line. > > There should be another one located under the sink where my redi- line > relay was located. > > I ended up putting my inverter/charger in place of the original > battery chargers and connecting them with 16' of 2/0 cable(s) to the > batteries in the left front battery bay. My right front bay has 2- 8D > starting batteries. > > I have more details on my inverter installation in the files section > of the FC_Wanderlodge Yahoo!Group. > > Good luck, > > Tim Hannink > Winter Park, FL > 1981 FC-33SB > > > > --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" > wrote: > > > > I picked up a 1500 watt inverter and need some help installing it. My > > coach does not appear to have ever had an inverter but I'm not sure, > > there are no wires in the front left bay and most I've seen had a > > rediline in this location. So my question is are the Wanderlodges > > prewired for an inverter? If so where do I look for the connection > point? > > > > Troy Tikalsky > > Waconia, MN > > 1983 FC33 > > > |
