Air Issue (Not A/C) and Motor Cleaning
01-22-2006, 12:24
Greetings again,
Another little problem...when airing up the BB after sitting for a few days (all air in tanks depleted), the pressure climbs and stays at 30 PSI, and won't go any higher. I shut down the BB, and listen through the open hatch underneath the bed, and hear air excaping somewhere near the compressor. When it gets down to almost no pressure, I hear a click, and the hissing abruptly stops. I start up the BB again, and pressure climbs like normal up to the usual 125 PSI or so, and no hissing. This happens almost every time with the same result. I've kind of got used to the routine, but naturally I'm afraid of getting stuck somewhere with only 30 pounds of air pressure (can't release the brakes, suspension dumped, etc). Any ideas? I know there must be some kind of valve that is sticking, but I can't find it in all that mess of hoses and wires. Any sugestions? Also, looking down through the engine hatch underneath the rear bed, the engine is pretty gunked op with old oil, dirt, and the usual "road cake". Can I hurt anything by soaking it with engine degreaser (Sam's Club Purple Cleaner), and hitting with a hose or pressure washer? I'd like to get the snail shells, mouse poop, and the grime washed off so I can see what I'm looking at. The top of the motor makes a nice dining room for the neighborhood little critters, and I guess the snails are tasty but their shells aren't. OK to pressure wash it clean? Thanks, like always.... Kevin McKeown Yorba Linda, CA 1986 38' PT 8V92 |
01-22-2006, 13:26
At the bottom of your air drier is a valve that purges water. I call it a
spitter as it performs each time your air compressor cycles to its max pressure. Over time the spring that is supposed to closed the valve gets tired. A rebuild kit for the spitter valve is about 11.00 dollars, its a quite simple procedure. Should not have to remove the air drier to do this. All of this is based on having an AD-2 Bendix air drier. dandarst86fc35rbhuntleyil. >From: "Kevin McKeown" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Air Issue (Not A/C) and Motor Cleaning >Date: Mon, 23 Jan 2006 00:24:19 -0000 > >Greetings again, > >Another little problem...when airing up the BB after sitting for a >few days (all air in tanks depleted), the pressure climbs and stays >at 30 PSI, and won't go any higher. I shut down the BB, and listen >through the open hatch underneath the bed, and hear air excaping >somewhere near the compressor. When it gets down to almost no >pressure, I hear a click, and the hissing abruptly stops. I start >up the BB again, and pressure climbs like normal up to the usual 125 >PSI or so, and no hissing. This happens almost every time with the >same result. > >I've kind of got used to the routine, but naturally I'm afraid of >getting stuck somewhere with only 30 pounds of air pressure (can't >release the brakes, suspension dumped, etc). Any ideas? I know >there must be some kind of valve that is sticking, but I can't find >it in all that mess of hoses and wires. Any sugestions? > >Also, looking down through the engine hatch underneath the rear bed, >the engine is pretty gunked op with old oil, dirt, and the >usual "road cake". Can I hurt anything by soaking it with engine >degreaser (Sam's Club Purple Cleaner), and hitting with a hose or >pressure washer? I'd like to get the snail shells, mouse poop, and >the grime washed off so I can see what I'm looking at. The top of >the motor makes a nice dining room for the neighborhood little >critters, and I guess the snails are tasty but their shells aren't. >OK to pressure wash it clean? > >Thanks, like always.... > >Kevin McKeown >Yorba Linda, CA >1986 38' PT >8V92 > > > > |
01-22-2006, 15:50
Just a little more information that may help relative to parts for
the Bendix AD-2 air dryer. Check valve kit: Bendix 00287298 cost $6.93 Purge valve kit (spitter valve) Bendix 00287053 cost $13.94 Dissicant cartridge Bendix 0010900 cost $32.00 I got all of mine from NAPA although there are a lot of places on the internet that you can buy them at. Tom Warner 1982 FC35 Vernon Center,NY At 08:26 PM 1/22/2006, you wrote: >At the bottom of your air drier is a valve that purges water. I call it a >spitter as it performs each time your air compressor cycles to its max >pressure. Over time the spring that is supposed to closed the valve gets >tired. A rebuild kit for the spitter valve is about 11.00 dollars, its a >quite simple procedure. Should not have to remove the air drier to do this. >All of this is based on having an AD-2 Bendix air drier. > >dandarst86fc35rbhuntleyil. > > > >From: "Kevin McKeown" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Air Issue (Not A/C) and Motor Cleaning > >Date: Mon, 23 Jan 2006 00:24:19 -0000 > > > >Greetings again, > > > >Another little problem...when airing up the BB after sitting for a > >few days (all air in tanks depleted), the pressure climbs and stays > >at 30 PSI, and won't go any higher. I shut down the BB, and listen > >through the open hatch underneath the bed, and hear air excaping > >somewhere near the compressor. When it gets down to almost no > >pressure, I hear a click, and the hissing abruptly stops. I start > >up the BB again, and pressure climbs like normal up to the usual 125 > >PSI or so, and no hissing. This happens almost every time with the > >same result. > > > >I've kind of got used to the routine, but naturally I'm afraid of > >getting stuck somewhere with only 30 pounds of air pressure (can't > >release the brakes, suspension dumped, etc). Any ideas? I know > >there must be some kind of valve that is sticking, but I can't find > >it in all that mess of hoses and wires. Any sugestions? > > > >Also, looking down through the engine hatch underneath the rear bed, > >the engine is pretty gunked op with old oil, dirt, and the > >usual "road cake". Can I hurt anything by soaking it with engine > >degreaser (Sam's Club Purple Cleaner), and hitting with a hose or > >pressure washer? I'd like to get the snail shells, mouse poop, and > >the grime washed off so I can see what I'm looking at. The top of > >the motor makes a nice dining room for the neighborhood little > >critters, and I guess the snails are tasty but their shells aren't. > >OK to pressure wash it clean? > > > >Thanks, like always.... > > > >Kevin McKeown > >Yorba Linda, CA > >1986 38' PT > >8V92 > > > > > > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-24-2006, 15:20
Kevin, I have tried to email you and it was returned regarding the
CORRECT NAPA part #'s for the rebuild of the AD-2 air dryer. If you email me cme4boatsataoldotcom I will give you the NAPA numbers and you should be able to find the whole rebuild and descicant cartridge replacements for the air dryer. Scott B 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown" > > Greetings again, > > Another little problem...when airing up the BB after sitting for a > few days (all air in tanks depleted), the pressure climbs and stays > at 30 PSI, and won't go any higher. I shut down the BB, and listen > through the open hatch underneath the bed, and hear air excaping > somewhere near the compressor. When it gets down to almost no > pressure, I hear a click, and the hissing abruptly stops. I start > up the BB again, and pressure climbs like normal up to the usual 125 > PSI or so, and no hissing. This happens almost every time with the > same result. > > I've kind of got used to the routine, but naturally I'm afraid of > getting stuck somewhere with only 30 pounds of air pressure (can't > release the brakes, suspension dumped, etc). Any ideas? I know > there must be some kind of valve that is sticking, but I can't find > it in all that mess of hoses and wires. Any sugestions? > > Also, looking down through the engine hatch underneath the rear bed, > the engine is pretty gunked op with old oil, dirt, and the > usual "road cake". Can I hurt anything by soaking it with engine > degreaser (Sam's Club Purple Cleaner), and hitting with a hose or > pressure washer? I'd like to get the snail shells, mouse poop, and > the grime washed off so I can see what I'm looking at. The top of > the motor makes a nice dining room for the neighborhood little > critters, and I guess the snails are tasty but their shells aren't. > OK to pressure wash it clean? > > Thanks, like always.... > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > 8V92 > |
01-25-2006, 09:01
Kevin,
I think there may be some confusion between "NAPA" part numbers versus "Bendix" part numbers for the AD-2 Air Dryer. The part numbers listed in the prior response which is being referred to by Scott, are in fact the correct "Bendix" part numbers right off the Bendix spec sheet for the AD-2 dryer. You can go to http://www.bendix.com/products/ViewLiter...=AirDryers pull down menu - Page 13 has all the Bendix part numbers. I think even a NAPA counter guy could cross-reference the Bendix part number to one of their NAPA part numbers if need be. On the other hand, I have stood at a NAPA store for half an hour with the old NAPA part in hand, while they tried to find the NAPA Part Number printed on the old part....... The prices listed for the Bendix parts in the original post are about what I have paid at real truck parts houses, but they have usually been asking 2x those prices at the NAPA stores I have visited. Needless to say, I buy from the big truck parts counters. Mike Bulriss 1983 PT40 "Stagecoach" - For Sale 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Scott" > > Kevin, I have tried to email you and it was returned regarding the > CORRECT NAPA part #'s for the rebuild of the AD-2 air dryer. If you > email me cme4boatsataoldotcom I will give you the NAPA numbers and > you should be able to find the whole rebuild and descicant cartridge > replacements for the air dryer. > > Scott B > 86FC35 > SC > > --- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown" > > > > > Greetings again, > > > > Another little problem...when airing up the BB after sitting for a > > few days (all air in tanks depleted), the pressure climbs and stays > > at 30 PSI, and won't go any higher. I shut down the BB, and listen > > through the open hatch underneath the bed, and hear air excaping > > somewhere near the compressor. When it gets down to almost no > > pressure, I hear a click, and the hissing abruptly stops. I start > > up the BB again, and pressure climbs like normal up to the usual 125 > > PSI or so, and no hissing. This happens almost every time with the > > same result. > > > > I've kind of got used to the routine, but naturally I'm afraid of > > getting stuck somewhere with only 30 pounds of air pressure (can't > > release the brakes, suspension dumped, etc). Any ideas? I know > > there must be some kind of valve that is sticking, but I can't find > > it in all that mess of hoses and wires. Any sugestions? > > > > Also, looking down through the engine hatch underneath the rear bed, > > the engine is pretty gunked op with old oil, dirt, and the > > usual "road cake". Can I hurt anything by soaking it with engine > > degreaser (Sam's Club Purple Cleaner), and hitting with a hose or > > pressure washer? I'd like to get the snail shells, mouse poop, and > > the grime washed off so I can see what I'm looking at. The top of > > the motor makes a nice dining room for the neighborhood little > > critters, and I guess the snails are tasty but their shells aren't. > > OK to pressure wash it clean? > > > > Thanks, like always.... > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' PT > > 8V92 > > > |
01-25-2006, 09:12
Prior message meant to say:
When you go to the Bendix page, look under "AD-2 Air Dryer" for the Service Data Sheet in the pull down menu .... and then go to page 13 for all the Bendix part numbers. Lost that whole line when the message posted. Mike Bulriss 1983 PT40 "Stagecoach" - For Sale 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > > Kevin, > > I think there may be some confusion between "NAPA" part numbers versus > "Bendix" part numbers for the AD-2 Air Dryer. > > The part numbers listed in the prior response which is being referred > to by Scott, are in fact the correct "Bendix" part numbers right off > the Bendix spec sheet for the AD-2 dryer. You can go to > http://www.bendix.com/products/ViewLiter...=AirDryers > pull down menu - Page 13 has all the Bendix part numbers. > > I think even a NAPA counter guy could cross-reference the Bendix part > number to one of their NAPA part numbers if need be. On the other > hand, I have stood at a NAPA store for half an hour with the old NAPA > part in hand, while they tried to find the NAPA Part Number printed on > the old part....... > > The prices listed for the Bendix parts in the original post are about > what I have paid at real truck parts houses, but they have usually > been asking 2x those prices at the NAPA stores I have visited. > Needless to say, I buy from the big truck parts counters. > > Mike Bulriss > 1983 PT40 "Stagecoach" - For Sale > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > > > > Kevin, I have tried to email you and it was returned regarding the > > CORRECT NAPA part #'s for the rebuild of the AD-2 air dryer. If you > > email me cme4boatsataoldotcom I will give you the NAPA numbers and > > you should be able to find the whole rebuild and descicant cartridge > > replacements for the air dryer. > > > > Scott B > > 86FC35 > > SC > > > > --- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown" > > > > > > > > Greetings again, > > > > > > Another little problem...when airing up the BB after sitting for a > > > few days (all air in tanks depleted), the pressure climbs and stays > > > at 30 PSI, and won't go any higher. I shut down the BB, and listen > > > through the open hatch underneath the bed, and hear air excaping > > > somewhere near the compressor. When it gets down to almost no > > > pressure, I hear a click, and the hissing abruptly stops. I start > > > up the BB again, and pressure climbs like normal up to the usual 125 > > > PSI or so, and no hissing. This happens almost every time with the > > > same result. > > > > > > I've kind of got used to the routine, but naturally I'm afraid of > > > getting stuck somewhere with only 30 pounds of air pressure (can't > > > release the brakes, suspension dumped, etc). Any ideas? I know > > > there must be some kind of valve that is sticking, but I can't find > > > it in all that mess of hoses and wires. Any sugestions? > > > > > > Also, looking down through the engine hatch underneath the rear bed, > > > the engine is pretty gunked op with old oil, dirt, and the > > > usual "road cake". Can I hurt anything by soaking it with engine > > > degreaser (Sam's Club Purple Cleaner), and hitting with a hose or > > > pressure washer? I'd like to get the snail shells, mouse poop, and > > > the grime washed off so I can see what I'm looking at. The top of > > > the motor makes a nice dining room for the neighborhood little > > > critters, and I guess the snails are tasty but their shells aren't. > > > OK to pressure wash it clean? > > > > > > Thanks, like always.... > > > > > > Kevin McKeown > > > Yorba Linda, CA > > > 1986 38' PT > > > 8V92 > > > > > > |
