Removing backup monitor
02-02-2006, 11:21
My backup monitor appears to be the original monitor. I have replaced
the backup camera and it works great WHEN the monitor works. When I hit a bump in the road the monitor goes fuzzy and/or goes out. I bang on the dash and it comes on again. I assume there is a loose connection somewhere, but I can't seem to figure out how to get to the back of the monitor. I removed the plastic cover and there are 4 hex head screws on the face of the monitor. One screw is covered by a corner block for the screw of the plastic dash cover. I looked underneath through the CB compartment and there is a big aluminum Z bracket that supports the monitor. Again, some of the screws are exposed but at the other end of the Z they are buried. All I want to do is reseat the connections and things should be good. Any ideas? Brian Gatley 93 WLWB PT40 Bend, OR [Non-text portions of this message have been removed] |
02-02-2006, 12:44
Brian I am sure you have the three drawers to the left of the cb compartment
right? Take the three drawers out. There is a process for removing them. Squeeze the black rubber-like protrusions you will find in the slides. Squeeze and lift at the same time and the drawer will leave the rails. Once you have all the drawers out look inside the drawer compartment and you will find screws in the side walls. Remove these screws and the compartment shell will slide forward and out. Under the compartment shell is the forward electric heater and now would be the time to give it a good look over and vacuum all the dust buggers out. Once the compartment shell is out you will have access to the rear of the monitor and you will see a green (about 2 inches by 3/8") electric connection. Pull the connection off and check it. Maybe clean contact surfaces. Doing it this way you don't have to pull the monitor out through the dash. If you decide to replace your system I have done this and will be able to help. Quoting Brian Gatley > > > > > My backup monitor appears to be the original monitor. I have replaced > > the backup camera and it works great WHEN the monitor works. When I hit > > a bump in the road the monitor goes fuzzy and/or goes out. I bang on > > the dash and it comes on again. I assume there is a loose connection > > somewhere, but I can't seem to figure out how to get to the back of the > > monitor. > > > > I removed the plastic cover and there are 4 hex head screws on the face > > of the monitor. One screw is covered by a corner block for the screw of > > the plastic dash cover. > > > > I looked underneath through the CB compartment and there is a big > > aluminum Z bracket that supports the monitor. Again, some of the screws > > are exposed but at the other end of the Z they are buried. > > > > All I want to do is reseat the connections and things should be good. > > > > Any ideas? > > > > Brian Gatley > > 93 WLWB PT40 > > Bend, OR > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > > |
02-02-2006, 12:44
Opps. I meant three drawers to the right of the CB compartment.
