shock absorbers
02-22-2006, 14:54
shock absorbers
I have a 1983 fc-35, don't know if i need shocks or not coach has
about 80,000 miles on it and wouldDoes the old test apply? if one sees oil its bad, if i can move it by hand i would also assume its bad, any other tips?, i have dirt driveway with several rough spots and she wallows back and forth. I will check the hard bar from body to axle before checking the shocks. finally what shock do i buy, i don'texpect these folks around here to have much knowledge. I waaant to thank all of you for the information you have provided re brake 1983 fc-35 SB |
02-22-2006, 16:17
shock absorbers
The shocks are Koni 90-2497SP1 available from BB. Use the procedure
at http://www.koni-na.com/adjustment.cfm for the 90 series and you will probably find that your shocks are still fine. Clean them up and reinstall them. They are probably the older version and will need new rubber bumpers which I believe Ralph Fullenwider has. Tom warner 1982 FC35 Vernon Center,NY s and are fully adjustable for the life of the shocks as long as they do not leak much.At 09:54 PM 2/22/2006, you wrote: >I have a 1983 fc-35, don't know if i need shocks or not coach has >about 80,000 miles on it and wouldDoes the old test apply? if one sees >oil its bad, if i can move it by hand i would also assume its bad, any >other tips?, i have dirt driveway with several rough spots and she >wallows back and forth. I will check the hard bar from body to axle >before checking the shocks. finally what shock do i buy, i don'texpect >these folks around here to have much knowledge. >I waaant to thank all of you for the information you have provided > >re brake 1983 fc-35 SB > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
02-22-2006, 16:45
shock absorbers
If you need new shocks, I found the best price for Koni Shocks at
<http://www.shox.com> Shipping was even free. At least give them a try. Much better price than BB. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD Now enjoying the balmy Gila Bend, AZ. Tom Warner wrote: > The shocks are Koni 90-2497SP1 available from BB. Use the procedure > at http://www.koni-na.com/adjustment.cfm for the 90 series and you > will probably find that your shocks are still fine. Clean them up and > reinstall them. They are probably the older version and will need new > rubber bumpers which I believe Ralph Fullenwider has. > > Tom warner > 1982 FC35 > Vernon Center,NY > > > > > s and are fully adjustable for the life of the shocks as long as they > do not leak much.At 09:54 PM 2/22/2006, you wrote: > >>I have a 1983 fc-35, don't know if i need shocks or not coach has >>about 80,000 miles on it and wouldDoes the old test apply? if one sees >>oil its bad, if i can move it by hand i would also assume its bad, any >>other tips?, i have dirt driveway with several rough spots and she >>wallows back and forth. I will check the hard bar from body to axle >>before checking the shocks. finally what shock do i buy, i don'texpect >>these folks around here to have much knowledge. >>I waaant to thank all of you for the information you have provided >> >>re brake 1983 fc-35 SB >> >> >> >> >> >>SPONSORED LINKS >><http://groups.yahoo.com/gads?t=ms&k=Recr...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn\ _ObWmSYTw>Recreational >>vehicles >><http://groups.yahoo.com/gads?t=ms&k=Wand...&w2=W\ anderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr\ eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>\ Wanderlodge >><http://groups.yahoo.com/gads?t=ms&k=Auto...43;ve\ hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w\ 5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy\ 34cC1O9CxA>Automotive >>maintenance >><http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xaha\ eYHfELr6o72IW1A>Recreational >>vehicle dealer >><http://groups.yahoo.com/gads?t=ms&k=Used...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4\ L-kXbDI4ZSadEw>Used >>recreational vehicles >><http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTn\ Mq_4GlXA>Automotive >>radiators >> >> >>---------- >>YAHOO! GROUPS LINKS >> >> * Visit your group >>"<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. >> * >> * To unsubscribe from this group, send an email to: >> * >> rlodgeForum-unsubscribe@yahoogroups.com >> >> * >> * Your use of Yahoo! Groups is subject to the >><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. >> >> >>---------- > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
02-22-2006, 20:25
shock absorbers
Last weekend, Steve Gureasko and with a little help from me, removed both
front Koni's on my pt. Found out that one of them could be adjusted firmer, but the other shock was toast. Lucky for me, Steve had replced his Konis and I was the recipient of one of the discards. What a difference in ride and handling just adjusted shocks make. We drove on I-10 to the rally and in places the road seemed almost non-existant. My DOA shock showed no sign of leakage and the rubber grommetts were intact. If your ride and handling is giving you a lot of fatigue at the end of your ride, shocks may be the culprit. Ernie Ekberg, 83pt40 in Texas [Non-text portions of this message have been removed] |
02-23-2006, 02:54
shock absorbers
FWIW, When I was going thru this on my Bird, I has a long conversation
with the factory engineer at Koni. He told me that a small amount of oil on the shock was perfectly acceptable since some was used to lubricate the seals. If it was "running" down the shock, then that was a problem. That was different from what I had been taught in years past - but things do change. I really loved those Koni shocks. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD enjoying the warm sun in Gila Bend, AZ erniecarpet@... wrote: > Last weekend, Steve Gureasko and with a little help from me, removed both > front Koni's on my pt. Found out that one of them could be adjusted firmer, but > the other shock was toast. Lucky for me, Steve had replced his Konis and I > was the recipient of one of the discards. What a difference in ride and > handling just adjusted shocks make. We drove on I-10 to the rally and in places the > road seemed almost non-existant. My DOA shock showed no sign of leakage and > the rubber grommetts were intact. If your ride and handling is giving you a > lot of fatigue at the end of your ride, shocks may be the culprit. Ernie > Ekberg, 83pt40 in Texas > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > |
04-02-2010, 11:28
shock absorbers
I have an 83FC35 with KONI shocks on the front, I want to change them because
the Bird (3208 250T CAT)is a wild ride with the rocking back and forth. I hope this is not normal! Does anyone know what a replacement shock would be? And where would one go to get one? Thanks Bill |
04-02-2010, 11:33
shock absorbers
04-02-2010, 11:42
shock absorbers
04-02-2010, 13:49
shock absorbers
Look at the bottom of this page of adjustment instructions:
http://www.koni.com/193.html Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 4/2/2010 at 4:42 PM Bill Mills wrote: >Wonderful news!à How does on go about this?à Do you undo the bottom and >rotate the shaft, clockwise from the bottom to stiffen and counter >clockwise from the bottom to weaken? >Thanks >Bill Livingston Texas > >--- On Fri, 4/2/10, Ernie Ekberg > >From: Ernie Ekberg >Subject: Re: [WanderlodgeForum] Shock Absorbers >To: WanderlodgeForum@yahoogroups.com >Date: Friday, April 2, 2010, 6:33 PM > > > > > > > >à > > > > > > > > > > Bill, those shocks are adjustable. >Ernie- Dillon, Mt > > >Ernie Ekberg >83PT40 >Wanderlodge >Weatherford, Txà 817-475-3991 >http://www.ernieekbergfloo ring.net > >--- On Fri, 4/2/10, colitatx > > >From: colitatx >Subject: [WanderlodgeForum] Shock Absorbers >To: WanderlodgeForum@ yahoogroups. com >Date: Friday, April 2, 2010, 6:28 PM > > >à > >I have an 83FC35 with KONI shocks on the front, I want to change them >because the Bird (3208 250T CAT)is a wild ride with the rocking back and >forth. I hope this is not normal! Does anyone know what a replacement >shock would be? And where would one go to get one? >Thanks Bill |
04-03-2010, 06:51
shock absorbers
If your rear shocks are original, they are shot and are not adjustable. I
tightened my front shocks about 1/2 turn from full stiff and replaced the rear shocks with much improvement. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "colitatx" > > I have an 83FC35 with KONI shocks on the front, I want to change them because the Bird (3208 250T CAT)is a wild ride with the rocking back and forth. I hope this is not normal! Does anyone know what a replacement shock would be? And where would one go to get one? > Thanks Bill > |
