Black Tank Sensors
03-05-2006, 14:43
Black Tank Sensors
Folks,
My LED tank monitor for my black water tank always shows that the tank is full even though I just emptied the tank. I've heard that there are stainless steel screw sensors that I can remove from the side of the tank for cleaning to get the tank monitor behaving properly. Does anyone know where exactly these sensors are on my '02 LXi? I'm having trouble finding them. Thanks, David Brady '02 LXi, Smokey, Va -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.375 / Virus Database: 268.1.2/274 - Release Date: 3/3/2006 |
03-05-2006, 23:58
Black Tank Sensors
David i use a tank wand, a piece 3/4 cpvc with one hole in the bottom
an three on the sides at the bottom i think about 1/8 in dia. With a valve on the top to cut off. It is about 40 inches. Works every time. You can buy one at camper supply. The holes may be little larger can always drill bigger. Jack Jones 57 pt 40 East Tn 40 deg. an rain |
03-06-2006, 02:33
Black Tank Sensors
Hi David,
It could be an accumulation of gunk, toilet paper, etc. across the top sensors. If you haven't already tried cleaning, here is a process that works for us. Accumulate about 1/4 liquids in the tank. Add 1 or 2 cups of low-sud-zing dishwasher-type detergent/soap to the tank and drive 50 or more miles to allow the detergent to do its thing. Immediately after stopping, drain the tank. We try to remember to do this at the end of each trip. John & Amy Suter 2000LXi --- David Brady > Folks, > > My LED tank monitor for my black water tank always > shows that the tank is full even though I just > emptied the > tank. I've heard that there are stainless steel > screw sensors > that I can remove from the side of the tank for > cleaning > to get the tank monitor behaving properly. Does > anyone > know where exactly these sensors are on my '02 LXi? > I'm having trouble finding them. > > Thanks, > David Brady > '02 LXi, Smokey, Va > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.375 / Virus Database: 268.1.2/274 - > Release Date: 3/3/2006 > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-08-2006, 11:32
Black Tank Sensors
Howdy, David.
--- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > My LED tank monitor for my black water tank always > shows that the tank is full even though I just emptied the > tank. I've heard that there are stainless steel screw sensors > that I can remove from the side of the tank for cleaning > to get the tank monitor behaving properly. Does anyone > know where exactly these sensors are on my '02 LXi? > I'm having trouble finding them. > > Thanks, > David Brady > '02 LXi, Smokey, Va > We always have a similar problem. Jack uses the tank flusher until the LEDs read on the E or 1/4 full on the waste tank indicator. Sometimes there is some debris hung up on the sensors and it just has to be washed off by the tank flusher. But then our sensors are IN the black water tank. Hmmmm. Regards, Jack and Liz Pearce Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
