Dash A/C
12-29-2011, 04:17
Dash A/C
No compressor, no cooling.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@...> wrote: > > Where does the dash AC get it cooling from? My 1983 PT WL does not have a > AC compressor on the engine. > > > > Bill > > 1983 PT 36 BBWL > > > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002 > Sent: Wednesday, December 28, 2011 9:42 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Dash A/C > > > > > > System is fully charged, but I did not think to close off the heat manual > valves to see if that is the problem. I'll check that on the next warm day. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Hi Ron, If your freon charge is a little low the system will work fine for > a little while until the evap. coil under your dash freezes up turning into > a block of ice and and then cooling stops. > > Also like you mentioned it could be the warm air from the front heat > warming your conditioned air, did you shut off the valve or valve's in the > heater hose supply lines to the front heat? > > Ã > > Wayne kotila > > 1996 PT42 > > Ã > > > > > > ________________________________ > > From: ronmarabito2002 > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Tuesday, December 27, 2011 8:53 AM > > Subject: [WanderlodgeForum] Dash A/C > > > > > > Ã > > Does anyone have a schematic for plumbing and electrical on the Dash A/C > for a 92 Wanderlodge? > > > > I continue to have my dash a/c quit cooling after a short time while > driving. System is full of freon and cools effectively for a short time. > > > > It may be possible that the defrost heat is mixing with the a/c or the > thermostat is cutting off the compressor. Anyway, any help would be > appreciated. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > |
