Manual shut off?
03-16-2006, 03:17
Manual shut off?
On many diesels, there is a manual shut off switch for the engine if
the key switch fails to stop fuel delivery. I haven't seen one on my FC with CAT 3208. Is there one? If not, what is the emergency shut off procedure? I know putting a plastic bag around the air filter will probably solve the problem, but I'm curious as to whether BB built an alternative into the system from the start. I've seen at least a few accounts of 3208's running away as a result of bad seals in the turbo fueling the engine with oil. Kerry 82 FC 35 Denver |
03-16-2006, 15:09
Manual shut off?
Take the wire off the fuel soleniod on top of the fuel service assembly, without
voltage applied the solenoid should drop shutting off the fuel.to start it you will have to connect the wire back up to apply voltage.if all else fails remove the solenoid and put finger in the hole and push down on the fuel control. you will have to pull it up manually to start. re 1983 fc-35 sb -------------- Original message from "davidkerryedwards" On many diesels, there is a manual shut off switch for the engine if the key switch fails to stop fuel delivery. I haven't seen one on my FC with CAT 3208. Is there one? If not, what is the emergency shut off procedure? I know putting a plastic bag around the air filter will probably solve the problem, but I'm curious as to whether BB built an alternative into the system from the start. I've seen at least a few accounts of 3208's running away as a result of bad seals in the turbo fueling the engine with oil. Kerry 82 FC 35 Denver SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
03-17-2006, 16:43
Manual shut off?
Kerry
The 2 cycles had them in the event of a run away which could happen the manual shutoff on the Detroits was butterfly valve in the intake that once fliped closed the air off. When I went thru heavy truck school years ago, training engines would have to be perodically destroyed when the training value was used. A previous class had used the plastic bag you mentioned and came close to burning down the building as the melting plastic travled thru the dyno exhaust. We destroyed an 8v. We ran it with no water,a cup of screws thru the inlet, no oil and finally a cup of blasting sand thru the inlet. We went to lunch let it cool came back and the beast still tried to start just not enough compression. If you need something to put in fornt of the intake for emergency I would suggest a steel plate Hugh still looking Thomaston Ga --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > On many diesels, there is a manual shut off switch for the engine if > the key switch fails to stop fuel delivery. I haven't seen one on my > FC with CAT 3208. Is there one? If not, what is the emergency shut > off procedure? I know putting a plastic bag around the air filter > will probably solve the problem, but I'm curious as to whether BB > built an alternative into the system from the start. > I've seen at least a few accounts of 3208's running away as a result > of bad seals in the turbo fueling the engine with oil. > > Kerry > 82 FC 35 > Denver > |
