What is this sensor?
03-23-2006, 10:53
There is a sensor on my bus that is crushed
not know what its for. Apparently someone did not like this electronic device, because it has been smashed..??$^*#$@# My hunch is the "panic button" Buzzer in the kitchen.? It is to the right of the florescent Light above the sink. When I hit the 'panic button' nothing happens. However, could be wrong... I have posted a picture under "files section" that I will delete in a day or so if you can check it out. Thank you, Stephen 81 FC-33SB Plant City, FL |
03-23-2006, 11:40
Doesn't help us much since you didn't give us a picture of the button
or sensor. All you show in your picture is where it is located. You would be surprised at how different each coach can be and each years location of controls and sensors. Send a shot looking at the specific sensor. Thanks, R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > There is a sensor on my bus that is crushed > not know what its for. Apparently someone did not like this electronic > device, because it has been smashed..??$^*#$@# > > My hunch is the "panic button" Buzzer in the kitchen.? It is to the > right of the florescent Light above the sink. When I hit the 'panic > button' nothing happens. However, could be wrong... I have posted a > picture under "files section" that I will delete in a day or so if you > can check it out. > Thank you, > Stephen > 81 FC-33SB > Plant City, FL > |
03-23-2006, 12:00
I know- I didn't have one here at home.:-( I will go to the bus and get a
picture of the broken sensor (what's left of it) . Thanks, Stephen 81 FC-33SB Plant City, FL _____ _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002 Sent: Thursday, March 23, 2006 6:41 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: What is this sensor? Doesn't help us much since you didn't give us a picture of the button or sensor. All you show in your picture is where it is located. You would be surprised at how different each coach can be and each years location of controls and sensors. Send a shot looking at the specific sensor. Thanks, R.E. (Ron) Marabito, Dallas, tX 92WB40 [Non-text portions of this message have been removed] |
03-23-2006, 12:33
I can't see it in the photo, but it is probably the indoor
temperature sensor (thermistor) for the galley monitor panel. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > There is a sensor on my bus that is crushed > not know what its for. Apparently someone did not like this electronic > device, because it has been smashed..??$^*#$@# > > My hunch is the "panic button" Buzzer in the kitchen.? It is to the > right of the florescent Light above the sink. When I hit the 'panic > button' nothing happens. However, could be wrong... I have posted a > picture under "files section" that I will delete in a day or so if you > can check it out. > Thank you, > Stephen > 81 FC-33SB > Plant City, FL > |
