Back up Camera AGAIN!
04-15-2006, 03:50
Just use what you have to to make the system work the line loss on
rg59 versus rg6 in 35 feet is inconsequential unless you have the eyes of a hawk we are not tlking high def here. we simply want to watch the rear not the ants walking behind the coach Stephen 7735fc --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Unless you either have swept cable or RG6 installed in your coach you > will degrade the picture on the monitor. RG59 if that is what you > have installed is alright for analog signals (the system originally > installed) but you will not get a sharp picture on the monitor if you > use it. Buying an adapter to connect two different cables is not the > answer. Fish the new cable and do it correctly. > > Tom Warner > Vernon Center,NY > 1982 FC35 > 1985 PT40 > > At 11:24 AM 4/15/2006, you wrote: > >Woody check out http://www.rvcams.com and if you do a search for a post I made about > >May of last year you'll get the Radio Shack part number for the connection > >that joins S cable and the existing Coax. Saves you having to fish new wire. > > > >Rob, Sue & Merlin > >94 WLWB > > > > > >Quoting rwoodysurplus > > > > > > |
04-15-2006, 04:31
Baseband video signals can also be transmitted over unshielded
twisted pair cable (AKA phone wire, you need suitable adapters for this). At least Category 3 UTP is recommended to provide attenuation properties similar to coaxial cable. These properties are sufficient for using UTP in such applications as video to the desktop and CCTV camera signals. Since most backup cameras are nothing more than CCTV camers, and not 3 chip CCD's it is more than adequate. For most baseband video application almost any well-made 75-ohm cable will be fine. The main requirements for video cable are adequate shield, and proper (75-ohm) impedance. If you get a poor signal consider replacing the connectors. A normal RG-59 cable (or better) is good to carry video signals (compsite video, S-video, RGB, component video etc.) for long distances. For best baseband video performance avoid cheap TV aerial cable, use proper pro-grade video cable, which has much heavier shielding. RG-59 baseband cable can be run to 600 feet, and the freq range is up to 3GHz. To sum it up the original cable run by BB is more than adequate, like everything else they put in the bus. Sorry for the rant ![]() Thanks Bruce Campbell 83FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Unless you either have swept cable or RG6 installed in your coach you > will degrade the picture on the monitor. RG59 if that is what you > have installed is alright for analog signals (the system originally > installed) but you will not get a sharp picture on the monitor if you > use it. Buying an adapter to connect two different cables is not the > answer. Fish the new cable and do it correctly. > > Tom Warner > Vernon Center,NY > 1982 FC35 > 1985 PT40 > > At 11:24 AM 4/15/2006, you wrote: > >Woody check out http://www.rvcams.com and if you do a search for a post I made about > >May of last year you'll get the Radio Shack part number for the connection > >that joins S cable and the existing Coax. Saves you having to fish new wire. > > > >Rob, Sue & Merlin > >94 WLWB > > > > > >Quoting rwoodysurplus > > > > > > |
04-15-2006, 04:36
Mine works great on twelve year old coax with the adapter. Picture is clear as
a bell. I suggest anyone interested buy the connector (it's cheap enough) and give it a try. If it works as well for you then you just might save yourself a lot of work. Of course if you want sound then you'll have to fish the S cable through. Rob, Sue & Merlin 94 WLWB Quoting Tom Warner > > > > Unless you either have swept cable or RG6 installed in your coach you > > will degrade the picture on the monitor. RG59 if that is what you > > have installed is alright for analog signals (the system originally > > installed) but you will not get a sharp picture on the monitor if you > > use it. Buying an adapter to connect two different cables is not the > > answer. Fish the new cable and do it correctly. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 > > 1985 PT40 > > > > At 11:24 AM 4/15/2006, you wrote: > > >Woody check out http://www.rvcams.com and if you do a search for a post I made > about > > >May of last year you'll get the Radio Shack part number for the connection > > >that joins S cable and the existing Coax. Saves you having to fish new wire. > > > > > >Rob, Sue & Merlin > > >94 WLWB > > > > > > > > >Quoting rwoodysurplus > > > > > > > > > > > > > > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > |
04-15-2006, 06:23
That's funny, Stephen...
Bob Lawrence 84 PT36 Tacoma, Wa We simply want to watch the rear not the ants walking behind the coach > Stephen 7735fc > |
