Koni shocks
04-20-2006, 09:03
Koni shocks
I read that Koni has come up with a new shock for the high end coaches.
I wonder, if they would fit my "use to be" high end coach, or are the fittings different? Ernie-83pt40 in Louisiana |
04-20-2006, 09:32
Koni shocks
The Koni FSD shocks used on the 450Lxi won't work on your Vintage Bird. They
are working on releasing some that will work on the vintage birds and think they may be available after October. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 20, 2006 5:03 PM Subject: [WanderlodgeForum] Koni shocks I read that Koni has come up with a new shock for the high end coaches. I wonder, if they would fit my "use to be" high end coach, or are the fittings different? Ernie-83pt40 in Louisiana ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-20-2006, 11:09
Koni shocks
> > I read that Koni has come up with a new shock for the high end coaches. > I wonder, if they would fit my "use to be" high end coach, or are the > fittings different? Ernie-83pt40 in Louisiana > |
04-20-2006, 11:09
Koni shocks
Ernie: That's funny!! Regards, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I read that Koni has come up with a new shock for the high end coaches. > I wonder, if they would fit my "use to be" high end coach, or are the > fittings different? Ernie-83pt40 in Louisiana > |
01-22-2008, 14:04
Koni shocks
Here are the part numbers for Koni shocks that were installed on my
87FC. Front: 90-2497 SP1 (adjustable) $149 each Rear: 9005-1025 FSD (self adjusting) $153 each Purchased from... ASI (619) 444-9766 Robert Britton 87FC Hollister, California |
05-12-2010, 15:49
Koni shocks
Ken, I know the Wanderlodge came from the factory with Koni shocks from the
1980s and newer and may have earlier than that as well, you should call Holland motorhomes, Parliament or Bleakley parts dept. Any of them should know. The Koni FSD is a new type of Koni shock that's supposed to give an improved ride and I am not shure if they have FSDs to fit anything older than around 2001 models. Wayne 96PT42 |
05-12-2010, 15:52
Koni shocks
Thanks for the info
