Aquahot Supply and Reriun Fuel lines 95-4203
05-05-2006, 01:24
Has anyone had to replace the supply and return fuel lines for the
Aqua hot? Mine are disintergrating from the inside out. Any pointers or tips would be greatly appreciated as they look like they run into the water closet, thanks! Pete and Donna Chin- The kids 95-4203 Greater Daytona Beach Area, Fl |
05-05-2006, 16:06
I have a wabasto on my bus and have never even looked at the line but
I have replaced rubber fuel lines on tractors using airbrake plastic line. The first repair was done onsite with the intent to replace the plastic with rubber when at my shop. I got the rubber but three years later the plastic airline is working too well to disturb. I think ?? the rubber dries out from the outside and the additives in the diesel pull the compromised rubber apart. Many would caution you to not use air line for fuel, I caution you not to replace a failed product with the same. There have been previous posts about diesel smells in newer coaches, I hope your find and repair avoids that problem. Do people who use Water Closets keep their beer in an Icebox? Gregory O'Connor 94pt40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "pgchd" > > Has anyone had to replace the supply and return fuel lines for the > Aqua hot? Mine are disintergrating from the inside out. Any pointers > or tips would be greatly appreciated as they look like they run into > the water closet, thanks! > Pete and Donna Chin- The kids > 95-4203 Greater Daytona Beach Area, Fl > |
