McCULLOUGH 2000 WATT PORTABLE GENERATOR
05-09-2006, 06:30
I just finished installing a McCullough 2000 watt portable generator,
in my trailer for use while dry camping to heat water or charge the 8 Trojan T-105 Golf cart batteries in my house battery bank. I installed it in a way that will allow me to easily remove the generator, if it is needed elsewhere. You can see my project at; http://www.pbase.com/iamflagman/image/59931690 This portable generator will run under full load @ 13,5 amps for four hours using one gallon of gas, so it will pay for itself in savings after just a short while. It cost me $591.45 including shipping from Sportsman's Guide, in Minnesota. At 64 db under full load it is not as quiet as a Honda powered generator of the same size, but it is not obnoxiously loud either, it is quieter than my Perkins Genset after I did all of the modifications to it, so it is tolerable, at almost half of the cost of a Honda. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA |
