Perkins Tune-up Shop?
05-15-2006, 12:47
Does anyone know of really good place to have the Perkins tuned up?
Mine has a tendancy to shake a bit once in a while, thinking the fuel injection timing could be adjusted as well as the injectors replaced maybe... Any comments on the things that should be considered with regard to the generator tune-up would be greatly appreciated. Jay Darst 85PT40 with Kohler/Perkins 12.5KW Generator Springfield, IL |
05-15-2006, 13:03
jay
fuel/air filters and power service you done changed the fuel pusher little pump right? the inj pump is gear to gear and should never ever go out of time if its bad and noticeable missing/skipping then have the inj POPed and cked out..... IMO Woody at ft bragg nc 18 yr army truck greaser with 81fcrb --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Does anyone know of really good place to have the Perkins tuned up? > > Mine has a tendancy to shake a bit once in a while, thinking the fuel > injection timing could be adjusted as well as the injectors replaced > maybe... > > Any comments on the things that should be considered with regard to > the generator tune-up would be greatly appreciated. > > Jay Darst > 85PT40 with Kohler/Perkins 12.5KW Generator > Springfield, IL > |
