Weather Striping
09-28-2006, 14:14
Weather Striping
Pete: I failed to tell you the easy way to identify the length of your stud.
Take one out and carefully scrap the paint off the top of the Phillips head.
There will be a number on it. Mine was 4. I had to use a mag glass to see it.
Eyes are the first thing to go I'm told. Any other parts going to @#$%doesn't
sound like any fun. Depending on the thickness of your seal your number should
be between -4 and -6.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Thursday, September 28, 2006 7:15 PM
Subject: Re: [WanderlodgeForum] Re: Weather Striping
Ok, to ensure we're talking about the same thing:
The phillips head diameter is (approx) 1/4 inch. The stud shaft is
1/8 inch in diameter. The distance to the pin (from the head) is
about 7/8 inch and about 1/8 inch extends past the pin. (So the
overall length is about 1 inch.) The spring is about 3/8 inch with
about 5 turns in that distance.
I didn't examine the fitting close enough to note that it could pass
through at an angle... but that certainly makes sense.
I found the data sheet for the 2700-4s at AircraftSpruce.com ... and
the price matches, so I guess that's where you found them as well.
I'll take a close look at the studs tomorrow and probably replace all
of them with stainless* as well... mine are showing a bit of rust,
but most have the head painted to match the coach.
*I replaced the Southco latch on the radiator door with stainless
(with a screwdriver/coin slot instead of hex key) after I had to
drill one out due to corrosion.
Thank you for the information.
Pete Masterson
aeonix1@...
'95 Bluebird Wanderlodge WBDA 42'
El Sobrante, CA
On Sep 28, 2006, at 3:49 PM, Leroy Eckert wrote:
> Hey Pete: My fasteners are not Dzus as I thought but are Camloc
> flush mount phillips head CAD plated studs. They are held in place
> by a internal tooth washer. They are easily removed by removing
> the washer and pulling out the stud. Removal of the cross pin is
> not required because the installer carved a small grove to allow
> the cross pin to pass through the cover at a 45 degree angle. I
> have decided to replace mine with stainless.
> PN 2700-4s for stainless-locking pin is 1" long-$1.60ea
> PN 2700-4 for CAD-$1.39ea
> Internal tooth washer-PN 2600-LW-$.18ea
> My bus takes 20ea
> The barrel of these studs are about 1/4" in diameter. The phillips
> screw head is slightly larger. There are various lengths.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
09-29-2006, 04:40
Weather Striping
Leroy, I got to admit, you've got a lot better eyesight than I have!
The number is barely noticeable ... but with a strong magnifier, I
was able to make out a "6" on the one from my coach.
Thanks.
You might be right about the eyes being the first to go.... I can't
remember what else might go first ... but give me a moment, it might
come to me... ... uh, let me think.... it's almost on the tip of my
tongue....
Pete Masterson
aeonix1@...
El Sobrante, CA
> your stud. Take one out and carefully scrap the paint off the top
> of the Phillips head. There will be a number on it. Mine was 4.
> I had to use a mag glass to see it. Eyes are the first thing to go
> I'm told. Any other parts going to @#$%doesn't sound like any fun.
> Depending on the thickness of your seal your number should be
> between -4 and -6.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
09-29-2006, 10:39
Weather Striping
OK, you have a -6 probably about 11/4 to 11/2 inch long. Is that about right?
Did you have a six tooth internal locking washer?
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Friday, September 29, 2006 11:40 AM
Thanks.
tongue....
Pete Masterson
aeonix1@...
El Sobrante, CA
> between -4 and -6.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
09-29-2006, 11:01
Weather Striping
I have to pop the panel off again to take a look... I have the broken
stud here by the computer (it broke at the cross-pin). Perhaps I'll
have time on Saturday to open it up.
Pete Masterson
aeonix1@...
El Sobrante, CA
> about right? Did you have a six tooth internal locking washer?
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Pete Masterson
05-29-2016, 09:48
RE: Weather Striping
Does anyone recall changing their front panel fasteners from the below post? Are these a direct replacement or require some modification to make fit?
http://www.aircraftspruce.com/catalog/ha...ey=3259860
Inflation has increased the price a bit.
[i]Posted by Leroy Eckert - 09-28-2006 08:49
Hey Pete: My fasteners are not Dzus as I thought but are Camloc flush mount
phillips head CAD plated studs. They are held in place by a internal tooth
washer. They are easily removed by removing the washer and pulling out the
stud. Removal of the cross pin is not required because the installer carved a
small grove to allow the cross pin to pass through the cover at a 45 degree
angle. I have decided to replace mine with stainless.
My bus takes 20ea
The barrel of these studs are about 1/4" in diameter. The phillips screw head
Leroy Eckert
1990 WB-40
Niceville, FL
[/i]
Mark Kitchens
Athens, TX
1995 WB42
