advice needed on "unscrewing" sewer pipe from black tank etc.
09-29-2006, 00:00
Forum members whove done messed with grey and black tanks.
I am about to put on drainmasters and have all the ABS pipe and elbows etc...I am concerned that I have to get off the "screw in" connector attached to the black tank....question..is there a special tool neede?? looks like ma big nut is attached to the black tank...does the screw attach to that? does any of this make sense...for anyone who has tackled this job..any cautions for me??? I am about to dump and flush my tanks and start the job in a couple hours....hope Tom Warner is listening... thanks..hope to hear from someone..... Regards, Hank Hannigan 80FC31 |
09-29-2006, 02:41
Hank,
I built a toy box trailer and had holding tanks built to my specs. The big nut was spun to the tank (spinning created heat to milt the two together). A fitting screwed into the big nut. Pipe, dump valves, etc. were glued to the fitting. My guess is the BIG NUT is glued to your tank. Is the pipe/fitting threaded where it meets the big nut? If so, a strap wrench might grip enough to turn the pipe. No threads would indicate the pipe/fitting is glued to the big nut. In that case you would need to cut the pipe leaving enough pipe to attach a coupling. Good luck. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Henry Jay Hannigan wrote: >Forum members whove done messed with grey and black tanks. >I am about to put on drainmasters and have all the ABS pipe and elbows >etc...I am concerned that I have to get off the "screw in" connector >attached to the black tank....question..is there a special tool >neede?? looks like ma big nut is attached to the black tank...does >the screw attach to that? does any of this make sense...for anyone >who has tackled this job..any cautions for me??? I am about to dump >and flush my tanks and start the job in a couple hours....hope Tom >Warner is listening... > >thanks..hope to hear from someone..... >Regards, >Hank Hannigan >80FC31 > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > |
09-30-2006, 10:43
My experience with the FC tanks is that the fitting is mounted to the
tank permanently. The fitting on the tank is a white PVC part, and the original pipe is black ABS. I have had no problem cutting the black pipe flush with the fitting, slotting the pipe using a spiral- cut bit on a dremmel (or equivalent) from the inside of the pipe, then driving a screwdriver between the pipe and fitting to pop the pipe pieces loose. The fitting should be un-damaged and can be prepped to glue in a new pipe. This is fairly easy if you are careful, as seeing white means you're through the pipe and into the PVC fitting. In my experience the original glue doesn't hold very well between the two plastics and removal is pretty clean. Make it easy to service in the valve and plumbing in your installation, the Drainmaster is a fairly fragile valve which can be damaged by a hit to the plumbing. You might want to leave plenty of pipe to cut and re-fit a new valve in the future and putting some type of guard under the pipe and valve should help to protect the it. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > Forum members whove done messed with grey and black tanks. > I am about to put on drainmasters and have all the ABS pipe and elbows > etc...I am concerned that I have to get off the "screw in" connector > attached to the black tank....question..is there a special tool > neede?? looks like ma big nut is attached to the black tank...does > the screw attach to that? does any of this make sense...for anyone > who has tackled this job..any cautions for me??? I am about to dump > and flush my tanks and start the job in a couple hours....hope Tom > Warner is listening... > > thanks..hope to hear from someone..... > Regards, > Hank Hannigan > 80FC31 > |
