Help...No Fresh Water From Pump...84FC
10-02-2006, 14:45
Pump runs , but will not build pressure. Tank may have been dry.
Lots of gurgling and the overflow hose from the tank is gurgling too. I believe my Sporlan tank fill valve is bad, but I have a manual shut-off on the tank fill connection...doesn't that eliminate the bad Sporlan valve? No water leaks inside or outside. I could probably figure this out, but I've got no time. Leaving for a road trip in 2 days. Advice appreciated. David Hollis 84 FC35 Springfield,IL |
10-02-2006, 15:24
David,
The Sprolan Valve is probable good, just needs cleaning... Based on our '87 PT... The water pump will run if the pump switch is on...that does not mean water is being pumped. The Sporlan valve controls the fill tank, or letting the pump pump water when the tank level is above the draw water level. With shore water connected the pump can be turned off (Sprolan in non-fill position) and you have shore water pressure. THAT IS TRUE IF ALL IS GOOD WITH THE SPORLAN VALVE... I have experienced what you describe. Remedy is...place some rags around the Sporlan valve, strip a rag so it can be inserted into the sporlan inlet water line after the top of the valve is removed (keeps the water from running in for the most part). Remove the top of the sporlan valve, insert the rag, clean out the valve(white scale stuff), scrape the rubber bladder (lightly) to remove the white scale. Then reinstall all the parts in reverse order. This takes no more than 15 minutes. Repeat the filling and pumping procedure. Good luck!. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dthollis1961 wrote: >Pump runs , but will not build pressure. Tank may have been dry. >Lots of gurgling and the overflow hose from the tank is gurgling >too. I believe my Sporlan tank fill valve is bad, but I have a manual >shut-off on the tank fill connection...doesn't that eliminate the bad >Sporlan valve? No water leaks inside or outside. I could probably >figure this out, but I've got no time. Leaving for a road trip in 2 >days. Advice appreciated. > >David Hollis 84 FC35 Springfield,IL > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
