Rediline relay
11-19-2006, 03:48
Rediline relay
MR,
I have looked everywhere for that relay. Must have sold it at one of
the RIV's swap meet.
Looked in the database, files in both forums, can't find the part
number.
Someone here has got that info. Could someone provide the part
number for the ice maker relay here?
Thanks
Jay Darst
85PT40
Springfield, IL
> M.R.,
> Replace the relay and the noise will be gone. If ya want, I'll see
if
> I still have one around here. I put it in and then shortly after,
> installed a Xantrex 2,500 watt inverter/charger. So, the rlay
comes
> out permanently with the inverter update.
> Where r u from?
> Does your dash a/c work?
> Jay Darst
> 85PT40
> Springfield, IL
> --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@>
> > Greetings All:
> > Anyone have a suggested modification to cure the noisy Rediline
> relay?
> > Perhaps a replacement latching relay that won't hum? I would
like
> to
> > keep the option of using the Rediline, but the noise is too
obnoxious
> > when in an otherwise quiet environment.
> > Thanks--
> > M.R.Kane
> > '85 PT40
11-19-2006, 10:33
Rediline relay
The "ice maker relay" part is as follows:
Potter Brumfield part number PRD11AGO-120
Magnacraft part number W199ABX-14 phone number 312-564-8800 Magnacraft 1910
Techny Rd. Northbrook, Illinois 60062
another source: wwwdotsmcelectonicsdotcom
dandarst86fc35rbhuntleyil.
>From: "Jay Darst"
>Subject: [WanderlodgeForum] Rediline relay
>Date: Sun, 19 Nov 2006 15:48:59 -0000
>MR,
>number.
>Thanks
>Jay Darst
>85PT40
>Springfield, IL
> > M.R.,
>if
>comes
> > Where r u from?
> > Jay Darst
> > 85PT40
> > Springfield, IL
> > wrote:
> > > Greetings All:
> > relay?
>like
> > to
>obnoxious
> > > Thanks--
> > > M.R.Kane
> > > '85 PT40
View Athlete’s Collections with Live Search
http://sportmaps.live.com/index.html?sou...ORM=MGAC01
11-19-2006, 15:21
Rediline relay
Thanks for the replies. The relay referenced is an "open" type. Is
this correct for our application in an environment where LP gas might
be present? [I haven't removed the cover on mine to look yet as it is
on the galley wall under the sink behind some plumbing. Only wanted to
fight the access problem once ;-) .]
--M.R.Kane
'85 PT40
Magnacraft 1910
11-19-2006, 15:42
Rediline relay
Cannot answer whether its an "open" type. Mine was enclosed in a steel
junction box typically used for electric connections, and was located in an
area similar to what you have described. I gave my new relay to John Finn
two or three years ago when I put in the new inverter, so I don't have it
any longer and do not use one.
>From: "mrkane1952" <mrkane@...>
>Subject: [WanderlodgeForum] Re: Rediline relay
>Date: Mon, 20 Nov 2006 03:21:25 -0000
>--M.R.Kane
>'85 PT40
>Magnacraft 1910
Get the latest Windows Live Messenger 8.1 Beta version. Join now.
http://ideas.live.com
