co-pilot seat air cylinder
12-26-2006, 14:10
My right hand seat slides back and forth and does not lock into the
desired postion.It appears that the cynlider retracts but will not come back out to engage the seat. When the switch is pushed does the air push the cylinder in? and when the switch is released the rod should come back out by spring pressure?. I see two "o" rings, other than that I don't see much to go wrong. Ant thoughts?? Thanks for all your help. re brake 1983 FC_35 sb |
12-26-2006, 15:47
Are you saying that it powers to the front and rear, or are we
talking rotating it to face the rear? I had a 83 FC35SB, and the front to rear was electric motor, turning to face the rear was a spring loaded release handle (no air involved). I beleive it originally had air for the back (lumbar support). If your is the same, the handle moves a locking mechanism in and out, it likely needs cleaning or has a broken spring. You should be able to lay on the floor, look underneath, and operate the controls to see what is happening (if it is the same as the 83 FC that I had.) Dan now in a 94 BB BMC 37' --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > My right hand seat slides back and forth and does not lock into the > desired postion.It appears that the cynlider retracts but will not > come back out to engage the seat. When the switch is pushed does the > air push the cylinder in? and when the switch is released the rod > should come back out by spring pressure?. I see two "o" rings, other > than that I don't see much to go wrong. Ant thoughts?? > Thanks for all your help. > re brake 1983 FC_35 sb > |
12-26-2006, 15:55
I think he's saying the side to side motion cannot be stopped. The cylinder is
not clamping down the mechanism when the seat needs to be fixed in position and it continues to slide side to side. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "ac7880" > > Are you saying that it powers to the front and rear, or are we > talking rotating it to face the rear? > > I had a 83 FC35SB, and the front to rear was electric motor, turning > to face the rear was a spring loaded release handle (no air involved). > > I beleive it originally had air for the back (lumbar support). > If your is the same, the handle moves a locking mechanism in and out, > it likely needs cleaning or has a broken spring. You should be able > to lay on the floor, look underneath, and operate the controls to see > what is happening (if it is the same as the 83 FC that I had.) > > Dan > now in a 94 BB BMC 37' |
12-26-2006, 23:33
Everything works except it slides from side to side not locking.I think the
cylinder is air disenged and spring engaged I didn't know it was suposed to rotate complely around to face the rear , it hits the dog house, Should it rotate completly? You guys are a weath of information, thanks for sharing it. re b5ake 1983 FC_35 sb > > From: "davidkerryedwards" > Date: 2006/12/26 Tue PM 10:55:08 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: co-pilot seat air cylinder > > I think he's saying the side to side motion cannot be stopped. The cylinder is not > clamping down the mechanism when the seat needs to be fixed in position and it > continues to slide side to side. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "ac7880" > > > > Are you saying that it powers to the front and rear, or are we > > talking rotating it to face the rear? > > > > I had a 83 FC35SB, and the front to rear was electric motor, turning > > to face the rear was a spring loaded release handle (no air involved). > > > > I beleive it originally had air for the back (lumbar support). > > If your is the same, the handle moves a locking mechanism in and out, > > it likely needs cleaning or has a broken spring. You should be able > > to lay on the floor, look underneath, and operate the controls to see > > what is happening (if it is the same as the 83 FC that I had.) > > > > Dan > > now in a 94 BB BMC 37' > > > > |
