Sump Air Problem
12-26-2006, 23:04
Sump Air Problem
Kevin, I have been plagued with a sticky ride height valve. Dump your
suspension and try it again. I have a personal solution to my problem. My left
side would not air up, but going out my drive the coach goes into a right hand
lean- airs those bags right up.
83PT40
Weatherford, tx
12-26-2006, 23:51
Sump Air Problem
Have a safe trip- glad I could help.
83PT40
Weatherford, tx
sometimes my suspension sticks- sometimes it doesn't~
12-27-2006, 03:50
Sump Air Problem
All:
I was getting ready to pull out this morning with my '82 PT-40 and the
sump warning light will not go out. After airing up the front and rear
air gauges show to be normal, but the Tag gauge is 0 PSI. The tag
airbags and the front airbags are "not" aired up, but I do not hear any
air leakage.
Anyone have any ideas, before I cancel my vacation?
Thanks.
Kevin Ford
1982 PT-40
Richmond, TX
12-27-2006, 04:12
Sump Air Problem
Thanks Ernie I will give that a try. If this doesn't work would it do
any damage to drive it to see if I can unstick something? Or drive 10
miles to a repair shop if I have too?
Thanks you and this Forum are livesavers....
Kevin
82 PT-40
Richmond Tx
your
problem. My left
right hand
> Ernie Ekberg
> 83PT40
> Weatherford, tx
12-27-2006, 04:20
Sump Air Problem
Erine that fixed me up she airing up now. Thanks you saved my
vacation!!!
On the road to San Marcos Tx...
Kevin Ford
82 PT-40
your
problem. My left
right hand
> Ernie Ekberg
> 83PT40
> Weatherford, tx
