Battery R&R
01-05-2007, 04:18
Battery R&R
This afternoon or tomorrow, I plan to remove the six 6V batteries and
install six new T-105s. My plan of attack is to have the Electronic Master Switch set to off, shore power disconnected, generator battery disconnected. Anything more that I should do before removing the six batteries? Thanks. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
01-05-2007, 05:06
Battery R&R
Curt:
On one of my 6 batteries is an overtemp pad which connects to the inverter/charger. Shut off the battery master switch at the batteries is there is one. Are they 6v batteries? Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Friday, January 05, 2007 10:18 AM Subject: [WanderlodgeForum] Battery R&R This afternoon or tomorrow, I plan to remove the six 6V batteries and install six new T-105s. My plan of attack is to have the Electronic Master Switch set to off, shore power disconnected, generator battery disconnected. Anything more that I should do before removing the six batteries? Thanks. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
01-05-2007, 05:50
Battery R&R
Thanks Leroy. I don't see anything out of the ordinary in the battery
compartment so I don't believe there is the overtemp pad. Yes, they are 6v batteries. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: >Curt: >On one of my 6 batteries is an overtemp pad which connects to the inverter/charger. Shut off the battery master switch at the batteries is there is one. Are they 6v batteries? > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL > > > > > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com > Sent: Friday, January 05, 2007 10:18 AM > Subject: [WanderlodgeForum] Battery R&R > > > This afternoon or tomorrow, I plan to remove the six 6V batteries and > install six new T-105s. My plan of attack is to have the Electronic > Master Switch set to off, shore power disconnected, generator battery > disconnected. Anything more that I should do before removing the six > batteries? Thanks. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > |
01-05-2007, 06:44
Battery R&R
Turn off the inverter(s) if they have separate switching.
Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Jan 5, 2007, at 8:18 AM, Curt Sprenger wrote: > This afternoon or tomorrow, I plan to remove the six 6V batteries and > install six new T-105s. My plan of attack is to have the Electronic > Master Switch set to off, shore power disconnected, generator battery > disconnected. Anything more that I should do before removing the six > batteries? Thanks. [Non-text portions of this message have been removed] |
01-05-2007, 07:15
Battery R&R
Thanks Pete! I'll add those to my list.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Pete Masterson wrote: >Turn off the inverter(s) if they have separate switching. > >Pete Masterson >aeonix1@... >'95 Blue Bird Wanderlodge WBDA 42' >El Sobrante, CA > > > > > |
01-05-2007, 12:48
Battery R&R
Curt,
I would do some streaching exercises and limber up a bit. The last time I pulled the batteries out my back hurt for two weeks. There is a non conducting strap tool designed to span the two polls and provide a handle to make it easier to lift the battery. Do you have one? Gardner 78FC33 (Ouch) --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > This afternoon or tomorrow, I plan to remove the six 6V batteries and > install six new T-105s. My plan of attack is to have the Electronic > Master Switch set to off, shore power disconnected, generator battery > disconnected. Anything more that I should do before removing the six > batteries? Thanks. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > |
01-05-2007, 16:57
Battery R&R
Gardner,
The strap came with the T-105s. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Gardner Yeaw wrote: >Curt, > I would do some streaching exercises and limber up a bit. The last >time I pulled the batteries out my back hurt for two weeks. There is >a non conducting strap tool designed to span the two polls and >provide a handle to make it easier to lift the battery. Do you have >one? > > Gardner > 78FC33 (Ouch) > >--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > >>This afternoon or tomorrow, I plan to remove the six 6V batteries >> >> >and > > >>install six new T-105s. My plan of attack is to have the >> >> >Electronic > > >>Master Switch set to off, shore power disconnected, generator >> >> >battery > > >>disconnected. Anything more that I should do before removing the >> >> >six > > >>batteries? Thanks. >> >>-- >>Curt Sprenger >>1987 PT38 8V92 "MacAttack Racing" >>Anaheim Hills, Calif. >> >> >> > > > > > >Yahoo! Groups Links > > > > > > |
