MAXTON MINI RALLY
02-10-2007, 20:33
MAXTON MINI RALLY
This is just a reminder that the Bluebird Mini Rally at Maxton is
just a little over six weeks away and counting, the dates are March
30 to April 1, 2007. This is two weeks after the rally at Myrtle
Beach and hopefully some of those attending the MB rally will be able
to stick around and then make the relatively short drive of a little
over 100 miles up to Maxton, NC for the Hot Rod Top Speed Challenge
that is held there. For more information go to the flyer at;
http://www.pbase.com/iamflagman/image/70827761
To see a map and directions to the track, plus photos of past mini
rallies at Maxton, just click on the flyer and it will take you to
the thumbnail page, then you can click on the thumbnail that you want
to see a larger version of.
Guy Smalley should have his Rat Rod done in time to make its maiden
run at Maxton during this event and the weather should be mild, so
normally you won't have to run the generator that long during this
dry camping rally, other than to charge your house batteries and the
spectator entry fee is only $5.00 per person for the entire event,
making this one of the least expensive rallies that you can attend,
so come join us for a fun filled time, you won't regret it.
It would be a good idea to use the forums sign up sheet located in
the Database section, to let us know if you are coming and also to
contact Barbara Vaughn about what food to bring.
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
HOPKINS, SOUTH CAROLINA
