FC Air Cleaner Change
02-22-2007, 02:42
Curious what others are doing on 3208's air cleaner element changes. Noted a
1-2 mpg drop in my mileage over the last few trips and thought the old girl might be having trouble breathing. I've run this filter for 40,000 miles and decided to change it on general principles. Old WIX element looked pretty dirty. Time will tell if it did any good. Any thoughts? Regards, Eric in San Antonio 84FC35SBWL2 |
02-22-2007, 03:28
I wonder if you paid less than $50 I am asking for the complete turbo aircleaner
assembly I have available, includes clean Wix filter. MH ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 22, 2007 8:42 AM Subject: [WanderlodgeForum] FC Air Cleaner Change Curious what others are doing on 3208's air cleaner element changes. Noted a 1-2 mpg drop in my mileage over the last few trips and thought the old girl might be having trouble breathing. I've run this filter for 40,000 miles and decided to change it on general principles. Old WIX element looked pretty dirty. Time will tell if it did any good. Any thoughts? Regards, Eric in San Antonio 84FC35SBWL2 [Non-text portions of this message have been removed] |
02-22-2007, 03:58
Eric, I'm not a fan of replacing filters just for a PM exersize but
if it was dirty and no restriction, you may have a leak in the element. Dirty filter with a drop in MPG is a "good sign" that the bird was laboring and the filter didnt fail but needs replacing. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > Curious what others are doing on 3208's air cleaner element changes. Noted a 1-2 mpg > drop in my mileage over the last few trips and thought the old girl might be having trouble > breathing. I've run this filter for 40,000 miles and decided to change it on general principles. > Old WIX element looked pretty dirty. Time will tell if it did any good. Any thoughts? > > Regards, Eric in San Antonio > 84FC35SBWL2 > |
02-22-2007, 04:06
Hi Mike,
Sounds like you have a good deal for anyone needing the whole assembly. Replacement WIX filter was $54 at local NAPA store. Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I wonder if you paid less than $50 I am asking for the complete turbo aircleaner assembly I have available, includes clean Wix filter. > MH > ----- Original Message ----- > From: Eric Johnson > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 22, 2007 8:42 AM > Subject: [WanderlodgeForum] FC Air Cleaner Change > > > Curious what others are doing on 3208's air cleaner element changes. Noted a 1-2 mpg > drop in my mileage over the last few trips and thought the old girl might be having trouble > breathing. I've run this filter for 40,000 miles and decided to change it on general principles. > Old WIX element looked pretty dirty. Time will tell if it did any good. Any thoughts? > > Regards, Eric in San Antonio > 84FC35SBWL2 > > > > > > [Non-text portions of this message have been removed] > |
