Batteries -- what is reasonable?
02-26-2007, 10:31
We just returned a few days ago from our last trip. We stayed in a
state park with no hook ups for 4 days. They had a quiet time from 8PM to 10AM. Our house batteries didn't seem to be "up" to the task of keeping the systems going. My coach is all-electric. Aside from cooking, the major draw is the refrigerator (a home-style side-by-side Amana). I have two 2500 watt inverters. The house batteries are six class 4D 12 v batteries with approximately 200 amp hour capacity each. So that's a total of 1200 amp hours. Using 50% as the cut off, that leaves 600 amp hours available to use. I don't have the exact specification for the refrigerator, but it's limited to a 15 amp breaker -- so let's assume that it draws 15amps. We had no other systems operating (no TV, no heat) except the 'phantom' loads that usually are present. The water pump would only operate if there was a 'flush' during the night (10 amps maximum at 12v but for only a brief period from time to time). So, if I calculate correctly, I have *no more than* (and probably a lot less than) a 30 amp per hour load times 14 hours or a maximum draw of 420 amp hours -- so I should have had no significant shortage of power in the morning starting with fully charged batteries in the evening before. (This, however, was not the case.) So... 1. I assume that the batteries aren't holding their charge as they should. This does not surprise me, since I was told they had been "abused" while in the hands of various dealers and intermediaries before I purchased the coach. 2. is my approximation on power correct? Should the batteries have held up better? (We sure would have liked to turn on the heat in the morning!) Am I missing something? We ran the generator 4 to 5 hours ... to bring the batteries up to a full charge (but I'm not sure they were fully 'up' -- but they should have been well past 90% charged). How long is typical to run a generator to recharge a set of house batteries? I plan to purchase a new set of house batteries, but thought I'd run this by the list first. Comments please? Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA [Non-text portions of this message have been removed] |
02-26-2007, 11:49
Pete, I think that your friend might be right. The old batteries could
have been abused, seriously compromising their performance. Are you sure they're deep-cycle? I had a friend that bought 4ea. 4-d 12v batteries from a local shop and they were not deep-cycle, you know thinner plates, quicker discharge and less depth of charge, they wouldn't last overnight. I know that my 12v batteries do not deliver the same performance now that they did when they were new and they haven't been abused, they just don't have the same depth of charge. I will be switching to 6v soon. Marty, 95 BMC 37 |
02-26-2007, 14:50
Pete, Are you maintaining hotwater with the inverter? I schedule
daily gen/run/battery charge time for periods of high use and prior to a need for hotwater. My chargers ( Yellow?? not OEM) have an "Equalizer" routine that is manualy prompted. The first time I completed the routine my batteries went to 14Volts and all the cells were truly even. Gregory O'Connor 94PTRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > We just returned a few days ago from our last trip. We stayed in a > state park with no hook ups for 4 days. They had a quiet time from > 8PM to 10AM. Our house batteries didn't seem to be "up" to the task > of keeping the systems going. > > My coach is all-electric. Aside from cooking, the major draw is the > refrigerator (a home-style side-by-side Amana). I have two 2500 watt > inverters. > > The house batteries are six class 4D 12 v batteries with > approximately 200 amp hour capacity each. So that's a total of 1200 > amp hours. Using 50% as the cut off, that leaves 600 amp hours > available to use. > > I don't have the exact specification for the refrigerator, but it's > limited to a 15 amp breaker -- so let's assume that it draws 15amps. > We had no other systems operating (no TV, no heat) except the > 'phantom' loads that usually are present. The water pump would only > operate if there was a 'flush' during the night (10 amps maximum at > 12v but for only a brief period from time to time). > > So, if I calculate correctly, I have *no more than* (and probably a > lot less than) a 30 amp per hour load times 14 hours or a maximum > draw of 420 amp hours -- so I should have had no significant shortage > of power in the morning starting with fully charged batteries in the > evening before. (This, however, was not the case.) > > So... 1. I assume that the batteries aren't holding their charge as > they should. This does not surprise me, since I was told they had > been "abused" while in the hands of various dealers and > intermediaries before I purchased the coach. 2. is my approximation > on power correct? Should the batteries have held up better? (We sure > would have liked to turn on the heat in the morning!) Am I missing > something? > > We ran the generator 4 to 5 hours ... to bring the batteries up to a > full charge (but I'm not sure they were fully 'up' -- but they should > have been well past 90% charged). How long is typical to run a > generator to recharge a set of house batteries? > > I plan to purchase a new set of house batteries, but thought I'd run > this by the list first. > > Comments please? > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > > > [Non-text portions of this message have been removed] > |
02-27-2007, 04:02
One other battery draw during inverterCamping could be chargers. I
have non OEM Chargers that donot turn off when the inverter is on. The previous owner set them up to plug into a non inverter outlet in the bay. AT a 30 amp Park the non inverter leg is not EdisonHot and I have to plug the chargers into a EdisonHot@30amp outlet which is also the inverter driven outlet (when inverter is on). I must remember to unplug the chargers from the inverter side prior to InverterCamping or I will be using the batterybank to charge the batterybank. (Pete, I know you are up on this but it deserves being posted) Chargers and good batteries are also necessary during 30and50ampCamping because much of the electric equipment is 12 volt battery driven. TexasMikeB recently did some charger repair update and he may shed some light from the LeaveUsAloneStar State. GregoryO'Connor 94PtRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > We just returned a few days ago from our last trip. We stayed in a > state park with no hook ups for 4 days. They had a quiet time from > 8PM to 10AM. Our house batteries didn't seem to be "up" to the task > of keeping the systems going. > > My coach is all-electric. Aside from cooking, the major draw is the > refrigerator (a home-style side-by-side Amana). I have two 2500 watt > inverters. > > The house batteries are six class 4D 12 v batteries with > approximately 200 amp hour capacity each. So that's a total of 1200 > amp hours. Using 50% as the cut off, that leaves 600 amp hours > available to use. > > I don't have the exact specification for the refrigerator, but it's > limited to a 15 amp breaker -- so let's assume that it draws 15amps. > We had no other systems operating (no TV, no heat) except the > 'phantom' loads that usually are present. The water pump would only > operate if there was a 'flush' during the night (10 amps maximum at > 12v but for only a brief period from time to time). > > So, if I calculate correctly, I have *no more than* (and probably a > lot less than) a 30 amp per hour load times 14 hours or a maximum > draw of 420 amp hours -- so I should have had no significant shortage > of power in the morning starting with fully charged batteries in the > evening before. (This, however, was not the case.) > > So... 1. I assume that the batteries aren't holding their charge as > they should. This does not surprise me, since I was told they had > been "abused" while in the hands of various dealers and > intermediaries before I purchased the coach. 2. is my approximation > on power correct? Should the batteries have held up better? (We sure > would have liked to turn on the heat in the morning!) Am I missing > something? > > We ran the generator 4 to 5 hours ... to bring the batteries up to a > full charge (but I'm not sure they were fully 'up' -- but they should > have been well past 90% charged). How long is typical to run a > generator to recharge a set of house batteries? > > I plan to purchase a new set of house batteries, but thought I'd run > this by the list first. > > Comments please? > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > > > [Non-text portions of this message have been removed] > |
02-27-2007, 07:49
Hot water is from the AquaHot system. I think (hope) that the 1500W
electric component that heats water for "immediate/light" demand doesn't work when I'm on inverter power. We didn't use any hot water while the generator was off, in any event. (The more common situation for inverter use is when we're on the road ... then the AquaHot picks up heat from the primary engine cooling system.) My inverter controller has a 'Equalizer' routine ... I ran it 3 or 4 months back, but it didn't have much effect. My best guess is that the current batteries are sulfated and probably beyond help. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 26, 2007, at 6:50 PM, Gregory OConnor wrote: > Pete, Are you maintaining hotwater with the inverter? I schedule > daily gen/run/battery charge time for periods of high use and prior > to a need for hotwater. My chargers ( Yellow?? not OEM) have > an "Equalizer" routine that is manualy prompted. The first time I > completed the routine my batteries went to 14Volts and all the cells > were truly even. > Gregory O'Connor > 94PTRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete > Masterson [Non-text portions of this message have been removed] |
