Sharp convection microwave model R930CS for my 90SP36 needed....WHERE???
03-02-2007, 14:16
I replaced my zap oven ,Sharp, when it wasn't operating. I do not know how it
cooks and really do not care to know. I just want it to work. However, I have
been told that zap ovens cook from the inside out, and are designed to shut off
when the door opens. Perhaps, the technician is correct, if it does not shut
off when the door opens, do not stick body parts in a zap oven, because that
would not be good<<<:>>>lol
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Friday, March 02, 2007 7:04 PM
Subject: Re: [WanderlodgeForum] Re: Sharp convection microwave model R930CS
A local guy fixed my original Sharp Convection/Micro, a couple of micro
switches. Said; DON'T OPEN DOOR WHEN THE OVEN IS OPERATING, SHUT IT OFF FIRST!
He was very assertive about that point.
MH
Sent: Friday, March 02, 2007 11:14 AM
Subject: [WanderlodgeForum] Re: Sharp convection microwave model R930CS for my
--- In WanderlodgeForum@yahoogroups.com, "Ron & Patty"
> Keith,
> Congrats with the new bus! According to the guy that repaired my
> Sharp, he said they are well worth keeping. You'll have to removed
> all the stainless panels around the unit and remove screws from the
> bottom. Anyway, once you get it out (it's a little heavy) you can
> remove the face and find a fuse inside there. Check the fuse first.
> If it continues to blow, you might have it repaired. Mine was for
> about $70.
> Ron, No. California
> 85PT36
> PS. Make sure your jacks are retracted before filling with fluid or
> you'll get an ATF bath.
> Are these things worth repairing? And how do
> > you get them out of the mounting?
> > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> > wrote:
> > > Where is a bargain source for subject model??
> > > Any deals out there?
> > > Thanks,
> > > Hank Hannigan
> > > 90SP36
Ron,
Where is that fuse for the Sharp convection microwave located exactly.
Also, did you find someone to work on it in the Sacto area?
I ran mine without anything inside. I know, it says in the book not
to operate the oven empty....oops
Harold Prescott
'85 FC35
Northern California
