1992 WB40 Battery Chargers
04-01-2007, 13:10
I have had my coach all of two weeks now and been having troubles
with the coach batteries. Today I pulled the inverter to get to the battery chargers. I can only get the batteries to charge if the High/Low switch was in high. I flipped the chargers around so I could get to the output legs and both where putting out 13+ volts. So I went to the engine bay and checked the high/low relay. As it turns out, with the switch in low I was not seeing any voltage at the relay. So that seemed odd as there was voltage at the charger output. So I figured I would pull the wire at the charger and ohm it out, it checked out fine. Then I looked at the wire on the charger end, and to my dismay, the factory installed the wire too deep into the charger and when the screwed down the keeper screw it was screwed down on the insulation. I put it back in and made sure it was not too far and screwed it down and it works like a champ now. The high charger is over heating, so I checked into that and the fan is dead, so ordered a new fan for that unit. Michael Brundridge 1992 WB40 - newbie Georgetown, TX |
