Air Bag Height
04-20-2007, 07:31
Air Bag Height
Anyone know what height the air bags should be set on a 1992 WB40?
I have a feeling mine are not correct. I am nose high, and leaning to the drivers side as well. So I am betting the front is too high, as well as the right rear corner. But before I start messing with it, I would like to know what height the bags on the front, drive, and tag axle should be so I can get them set properly. Michael Brundridge 1992 WB40 - currently un-named Georgetown, TX |
04-20-2007, 22:28
Air Bag Height
Mike
The Ridewell information that I have in my BLUE BOX for a 1993 is For a RAS-227 steer 6.75" For a RAD-227 Drive with Rockwell Axle 8.31" For a RAD-227 Drive with Eaton Axle 8.06" Let me know how the adjustment goes, the front on mine is about one inch too low right now. Steve Quandt Iron Mountain, MI 1993 PT-40 --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > Anyone know what height the air bags should be set on a 1992 WB40? > > I have a feeling mine are not correct. I am nose high, and leaning to > the drivers side as well. So I am betting the front is too high, as > well as the right rear corner. But before I start messing with it, I > would like to know what height the bags on the front, drive, and tag > axle should be so I can get them set properly. > > Michael Brundridge > 1992 WB40 - currently un-named > Georgetown, TX > |
04-21-2007, 15:16
Air Bag Height
Steve,
Thanks for that info, and reminding me that I should have looked in my blue box first as right after reading your response I looked and found my copy of the Ridewell book and it states the same info and how to adjust it. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "smquandt" wrote: > > Mike > > The Ridewell information that I have in my BLUE BOX for a 1993 is > > For a RAS-227 steer 6.75" > For a RAD-227 Drive with Rockwell Axle 8.31" > For a RAD-227 Drive with Eaton Axle 8.06" > > Let me know how the adjustment goes, the front on mine is about one > inch too low right now. > > Steve Quandt > Iron Mountain, MI > 1993 PT-40 > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > Anyone know what height the air bags should be set on a 1992 WB40? > > > > I have a feeling mine are not correct. I am nose high, and leaning > to > > the drivers side as well. So I am betting the front is too high, as > > well as the right rear corner. But before I start messing with it, I > > would like to know what height the bags on the front, drive, and tag > > axle should be so I can get them set properly. > > > > Michael Brundridge > > 1992 WB40 - currently un-named > > Georgetown, TX > > > |
